Or an Intel 12700 minimum and 16GB RAM.Unreal engine 5 as predicted is going to hammer GPUs and PCs in general
Ryzen 5700x and rtx3080ti to play 1440p 60fps on medium settings
Looks like that 4080 may not be so bad.
They also list an ssd as "very strongly recommended"
Isn't the RTX3080TI faster than an RTX4070 12GB?
It's a frame smoothing/motion blur technique not frame gen. It's not really a game changer like DLSS 2 upscaling was.Did I mention frame gen is a next level game changer?
Cat, you would scoff at £200 3080 performance, give it a rest. inflation, more expensive node. Jensen is not running a charity for gamers.
Have you used it.? it actually reduces motion blur as it gives you 2x the framerate and it is called frame generation in games.It's a frame smoothing/motion blur technique not frame gen. It's not really a game changer like DLSS 2 upscaling was.
Strictly speaking it does generate a new frame through, essentially, fancy interpolation. But the trade-off is it has to wait for the real frame that comes after it to do this so it increases latency.It's a frame smoothing/motion blur technique not frame gen. It's not really a game changer like DLSS 2 upscaling was.
Frame rate is still the same, it just creates the illusion of an extra frame to reduce judder. If they inserted a frame of dog poo you could technically say it generates a new frame, doesn't mean it would be any good though.Have you used it.? it actually reduces motion blur as it gives you 2x the framerate and it is called frame generation in games.
illusion or not it increases fluidity and reduces motion blur of a display.Frame rate is still the same, it just creates the illusion of an extra frame to reduce judder. If they inserted a frame of dog poo you could technically say it generates a new frame, doesn't mean it would be any good though.
I have a 40 series GPU but haven't bothered trying it, I've seen in-depth analysis and already know it's not worthwhile for me due to the artifacts and input lag.illusion or not it increases fluidity and reduces motion blur of a display.
I will ask again have you tried it yourself..?
It won't hurt to try it then.I have a 40 series GPU but haven't bothered trying it, I've seen in-depth analysis and already know it's not worthwhile for me due to the artifacts and input lag.
Haha. Although I somewhat agree. It is too funny coming from you Raven![]()
The €68 billion investment of U.S. tech giant Intel into a new microchips manufacturing site in the German city of Magdeburg could be Europe’s single largest foreign investment to date — but it's too early to claim this means Europe’s industrial policy on chips is a hit.
It still requireres a powerful GPU. 6800xt is still only a 1440p@60 low/medium with its 16GB. vRAM is meaningless without horsepower.12GB required for 1440P. 16GB for 4K
Unreal Engine 5 does not mess about, its a next gen engine and there are A LOT of games coming out on it in the next couple of years.
Thats the issue this time around where you have to pay £1200 for Nvidia to get next gen performance, everything under that is last gen and will not hold up well in the next gen games going forward.It still requireres a powerful GPU. 6800xt is still only a 1440p@60 low/medium with its 16GB. vRAM is meaningless without horsepower.
Performance between the 4070 and 4070Ti is the same as the difference between the 3070 and 3090, that's just absolutely horriffic and damning to Nvidia
