- 23 Jun 2004
- Blackburn
I went from 5600X to 5800X3D and boy I got improvements.
Temps on CPU can be higher, but it has better lows, and solid frames coming from it.
I have not noted any games where it is worse than my old 5600X. But have not measured them with any software.
This is simply from my impressions of using the chip.
To balance it out, Windows felt a tad slower to use with the new chip. I think the 5600X boosts higher than the 5800X3D in single core performance. The 5800X3D, goes up to 4.35 Ghrz, or so. The 5600X went over 4.5 Ghrz.
Yeah I'm not doubting the 5800X3D will be faster than my 5600X but I wondered if I'd get any benefit with my Vega 56. At this point I doubt a faster CPU will give me more fps in games as I'm pretty sure the gpu is what is holding me back right now. Unless someone with a similarly performing has made the jump to the 5800X3D and can say otherwise.
Interesting you mention the 5800X3D feeling slower in Windows. My 5600X is set to boost to 4750mhz all core, so if anything the 5800X3D might be a downgrade in my case.
