Man of Honour
- 23 Mar 2011
- West Side
You will need to update the motherboard bios so the new CPU works .Ah right, ok 5700x it is then!
No it won't. I explained how i'm thinking. I hate small upgrades once I build the system. AM5 vs AM4 is completely different. If you go with AM5 you are future proof. You can use your old hard drives, nvmes and Graphic card with AM5 but not Mobo, CPU, RAM or PSU.if his only theoretical expense is CPU which will keep system almost in pair with current AM5 rigs .. ?
new cooler? to keep up with AMDs requirements5700X is under £180 delivered right now and will be a big upgrade on a 1700X, you can barely buy an AM5 board for £180.
A 7600 non-X would perform similar to the 5700X in rendering, according to TPU, but that's £200+ and the board and the memory.
I 'think' I should be ok as I did that pretty recently, but good point, I'll double-check!You will need to update the motherboard bios so the new CPU works .
Ooh I never realised that could happen with bios upgrades, seems silly, but I'll wait as you say!!Make sure that by updating you don't lose support for your current CPU, if it needs updated I'd do so once your 5700X arrives.
Power usage difference between a 5700x and 5950x is much higher than 10-20w.katie279
What's your PSU? I still think it is a no-brainer to not go for 16c32t 5950 given only 10-20W of power usage difference
5950x is 142w in that chart not 105w.1700x is 95w chip vs 5950x 105w
That's why nobody recommended the 5800x and OP decided on a 5700x. 5950x is probably not worth it at the current price difference given that not all workloads will fully utilize the extra cores and they may need a new cooler.while suggested before 5800x is 140W - and also 5950 is double the cores
if you mean 65w 5700x which is not on the list probably small undervolt of 5750 will give similar results while still being 16c over 8c
what written just above for those interested - otherwise i feel there is some lobby of forcing worse over better around here for some reason
TDP-->65W = ~90W, 105W = ~140W of power.5950x is 142w in that chart not 105w.
