it's an MMI box ? - did they also find out why the gps had issuesUpdate on my android auto issue.
New Box installed, now all I do is press Menu for 3 seconds and Android Auto automatically connects to my phone via BT.
Happy days.
Happy days.
I just haven't found a mechanic I trust to be honest.. My local sytner seem decent enough and accommodating, and sorted any issues I had with the car without much fuss. Even replaced my inner roof liner free of charge (not a warranty item) due to how long it took to figure out an engine issue (during which they change loads of parts, including the high pressure fuel pump).I gotta say, I think you’re crazy to take a 12 year old car to a main dealer for servicing but each to their own. I’ve been taking my 2015 4 series to my local mechanic! Brake fluid change recently, £49 including fluid.
integratedautomotive.co.uk
Honestly I wouldn't bother. The internal nav is garbage - so you'll only ever use Waze anyway.![]()
BMW NBT EVO (2015 onwards) iD4/iD5/iD6 CarPlay and Android Auto Retrofit Kit - Integrated automotive UK
Datasheet: IMI-1000_- Datasheet_Sept_2024 pdf 3.52Mb The IMI-1000 is a retrofit compact multimedia interface that provides CarPlay and Android Auto connectivity in your BMW, utilising the original iDrive controls including iDrive controller and steering wheel. INTEGRATION WITH BMW STEERING WHEEL...integratedautomotive.co.uk
That's the box.
No clue about the GPS at this point in time.
I plan to flash the Screen back to standard via esys.
I hope that will solve the issue. If not, then I'll have to check the comms box located in.the rear.
We've done this discussion already.I used it all the time and always found it to be good.
iOS 16.5 came out yesterday which says it has CarPlay fixes in it, so definitely worth installing that and trying to reconnect.While we are discussing phone connectivity/satnavs- Has anyone had issues in the last week or two with Apple CarPlay refusing to connect to the car?
In my M340i G21, last week it dropped connection as I was out driving and now refuses to connect back up. I've tried deleting the phone from the car and 'forgetting' the car itself in the iOS settings. Also tried signing out of my BMW driver profile in iDrive then signing back in and setting up CarPlay again, but still no luck.
Finally tried a reset of the iDrive but again, refuses to connect.
Phone will connect via Bluetooth to iDrive and work via that, but if you try using CarPlay instead, it doesn't want to know.
Quite a few folk on some G20/G21 owners groups saying the same is happening to them and a few allege it's been an iOS update which has caused it, but no solutions appear to be forthcoming as yet.
Any ideas?
If you aren't using the in-built Satnav then if fitted, I believe a lot of those features are unavailable. I imagine headlights on bends is because the lights are connected to the steering rack.If GPS module is out, you'd loose other newer predictive, car reading the road, capabilities - auto gearbox selection at junctions/roundabouts (headlights on bends ?).
Excellent, didn't realise there was an update available. I had already rolled back the rapid response security 16.4.1 (A) patch as that seemed to be the culprit according to certain quarters. Have updated my iPhone with 16.5 and will pop out to the garage to see if its done the trick. Cheers for the 'heads up'iOS 16.5 came out yesterday which says it has CarPlay fixes in it, so definitely worth installing that and trying to reconnect.
I think it looks great, would love one![]()
The new BMW Concept Touring Coupe is a glorious Z4-based breadvan
3.0-litre sixer. Short, shooting brake rear. RWD. Just put it into production please, BMWwww.topgear.com
Can't decide if I love or hate this
*UPDATE* iOS 16.5 fixed my CarPlay connectivity issuesiOS 16.5 came out yesterday which says it has CarPlay fixes in it, so definitely worth installing that and trying to reconnect.
