I do lol. 6gb is puny in today's pixel powered world!Suspect you wish you had a bit more vram?
Fair enough to have free speech but you’re spreading disinformation as AMD have called their cards the names they have thought about that describes their cards the best in terms of performance.£450 should be the pricing if the 7800XT is on navi 32
Personally I think AMD should bin the 7800XT name this generation as that part has been used for the 7900XT, call this one a 7700XT and price at £400-450 while offering similar performance + more VRAM to the more expensive 4070 to get RDNA3 back on track and bring back some credibility.
You are mistaken. I’m happy with my 7900xt. It’s an amazing card and I love the fact that @Gibbo has made it the cheapest price in the land.
I can play on ultra due to the 20gb vram so that’s worth it to me.Great to hear so you can just ignore me ? , I have no issues with the 3080 vram is fine no game I play is needing any extra pretty happy got good value out of it going close to 3 years still high settings
I would not be happy playing at High settings if I spent £700 on a 3080 even if it was 2.5 years ago. If you had 12gb vram you could I suspect keep going for another 2 years. Anyhow you can always rely on Nvidia’s Jensen leather jacket charity next generation lolTbh honest if I had anything below the 3080 I'd probably be looking at the 7800xt sorry meant 7900xt lol, but at this moment in time perfectly happy with its performance
Both are terrible AMD could have rescued it more aggressive pricing? And instead naming 7900xt as 7800xt
The rdna3 architecture seems a failure or it just didn't go as planned, Nvidia Ada architecture is actually impressive but they gimped them a lot and placed in wrong tiers while increasing the price
Which is kind of dependant on the amount of compute units.doesn't matter what is inside it's the actual performance that matters.
I would not be happy playing at High settings if I spent £700 on a 3080 even if it was 2.5 years ago. If you had 12gb vram you could I suspect keep going for another 2 years. Anyhow you can always rely on Nvidias charity next generation lol
Maybe try reading what you're replying to.but it doesn't matter on the number only the performance.
7900XTX is better and cheaper than the 4080 so seems like it is doing ok. 7900XT better and cheaper than the 4070ti, I'm going to guess the 7800XT is going to be better and cheaper than the 4070.
if that was the case then the 7900XTX should be the 7800XT as it performs similar to a 4080 just like the 6800XT performed similar to a 3080, the 7900XT would then be the 7800 as it’s about 10% faster than a 4070ti just as the 6800 was 10% faster than a 3070ti.Fair enough to have free speech but you’re spreading disinformation as AMD have called their cards the names they have thought about that describes their cards the best in terms of performance.
Seems a bit of an odd thing to say when AFAIK they addressed some (most?) of the shortcomings of the 6000 series. (improved RT, AI cores, AV1) And before anyone says it I'm not saying those things are world beaters, I'm just saying they've improved those thing.The rdna3 architecture seems a failure or it just didn't go as planned, Nvidia Ada architecture is actually impressive but they gimped them a lot and placed in wrong tiers while increasing the price
I did, you said...read mine first.
And i said...doesn't matter what is inside it's the actual performance that matters.
I did, you said...
And i said...
Do you take glee out of criticising RDNA3 at every opportunity? It’s better than your 3080 or can’t you accept that?Of course you should be expecting improvements gen on gen
If you look at its spec on paper it should be performing better just seems something didn't go as planned
Fine wine will sort that.Of course you should be expecting improvements gen on gen
 youtu.be
					youtu.be
