Yea I did, pretty easy.Anyone rolled back to bios 317 - is it worth it and not too much hassle?
Did mine but now it wants to update to 319 every time I reboot..Yea I did, pretty easy.
What game/ bench ? Want to test myself.So.... When i try to play with max wattage, the CPU jumps to 95c super fast and then throttles hard. :/
Anyone else experiencing this?
Anyone got Hogwarts running ok?
With VRAM set to AUTO it compiles shaders in advance otherwise major stuttering - but AUTO makes Diablo 4 stutter..
Perf is only ok with max power..
On mine, i press the left macro key on back and then up. Brings up the keyboard. (i think its those keys)Had great fun last night getting Epic Installed. The actual process was relatively painless but then the keyboard would not automatically shown when tapping on the username / password boxes. Ok no problem, just tab on the keyboard icon in the task bar. That managed to bring up both the keyboard and also the start menu hence it started typing in the start menu. Sorted that out eventually and then got the same issue albeit different scenario when I tried creating a new folder on the SD card to move some Xbox Games. Created the new folder and again the keyboard didn't appear to change the name. Tapping on the keyboard icon brought it up (this time without the start menu) but closed the edit box on the folder. Long tap to rename and the option was beneath the keyboard... Rinse repeat.
I could have sorted all of this out by using a KB & mouse over a Single (or Bluetooth) but damn that was annoying in the moment and wouldn't have been an issue had the keyboard just appeared when it was supposed to.
I have experienced similar issues with the on screen keyboard on multiple devices running Win 10/11 so its not specific to the Ally (had it happen on the deck as well so very similar scenario).
Other than that I did managed to spend a bit of time messing around with CP2077. In game using Steam Deck settings it performs very much like the Deck albeit at a higher render resolution. 720p low saw ~52FPS in the in game benchmark but I ran out of time (was 00:30 at the time and I needed to be up at ~05:50) to test in game. Game looks excellent on the small screen even at "low" settings so at least you can push the FPS a little with not much loss in visuals (probably doesn't as good if you tried in a docked scenario mind).
In my own testing on the Deck I did find that dropping the GPU clock to max 1400Mhz gave a few extra FPS as it allowed the CPU to clock 2-300Mhz higher consistently. It would be nice to get that level of granular control for the Ally - controlling CPU / GPU power splits or max clocks when either CPU or GPU limited. This is where Armoury crate may cause issues if its anything like my Flow Z13. Around 50% of the time on that the XG Mobile 3080 can get stuck at a lower power limit or clock depending on what mood it is in or the general time of day.
Need to try with the hotfix driver and latest bios (Still on 3.17) to see if there is any difference.
I keep forgetting about the shortcuts. Tonight’s mission was to carry on testing only to be thwarted by the bios update and AMD hot fix update. No problem download and we are away..Wait, it needs power. Ok, XG Mobile do your thing and give life to the little Ally! No, stop asking to set up the XG Mobile… argh!It was available to me through the My ASU’s app. Initially it was shown in the optional section and then moved to essential. This was along with bios 319.Is the AMD Hotfix offered to you or do I have to go and get it manually? Nothing appeared on the Ally yet.
The little Z1 is quite the beast in normal desktop mode as well. Scores just over 14k (stock turbo settings) with a sustained all core of 3.8Ghz
