Yes I am fortunate in that I have use of a workshop.you evidently have the luxury of doing that inside a large building/workspace - both abrasive polishing and final polish outdoors are a lot less predictable with the sun/breeze and reduced working time available.
did you already say what shampoo you use ? the autoglym stuff I have, like many , leaves a shiny coat, I want a basic unadalterated/no e numbers, shampoo, if I will be polishing,
I have some older foreign 'Abel Auto' stuff - my good stuff - but am running out.
I use several different shampoo’s. I have Autoglym bodywork conditioner I use on a mostly as it’s decent day to day shampoo.
My favourite is Chrmical guys Cirtus Wash & Gloss fantastic stuff and economical.
				Chemical Guys - Citrus Wash & Gloss
Chemical Guys - Citrus Wash & Gloss  Chemical Guys - Citrus Wash & Gloss is a citrus base, hyper-concentrated car shampoo. Chemical Guys Citrus Wash & Gloss is the ultimate surface prep paintwork cleanser, shampoo and gloss enhancer in one and is 100% surface friendly.  The biodegrad
				 www.cleanyourcar.co.uk
				Hell Shine, The BaneBlade Shampoo 500ml
BaneBlade - By Hellshine Car Looking filthy?  No fear, simply slice away at the dirt with BaneBlade!   The new evil super concentrated safe PH Neutral shampoo used on your car or motorbike. Safe on all paint, metal, chrome, trim, leather, and wheel surfaces. In fact BaneBlade is safe for every...
				 www.justcarcare.co.uk
				Chemical Guys - Hydro Suds Ceramic Car Shampoo
Chemical Guys - Hydro Suds Ceramic Car Shampoo Chemical Guys Hydro Suds Ceramic Car Wash Soap combines a hyper-foaming pH neutral soap with the high-gloss shielding properties of SiO2 to deliver a hydrophobic wash that delivers a brilliant jaw dropping shine. Chemical Guys Hydro Suds is infused wi
				Meguiars Soft Wash Gel Shampoo (473ml)
Meguiars Soft Wash Gel Shampoo Another one of Megiuars products that has built up a strong fan base. This is one of the original formulas from Meguiars and as the saying goes, ‘if it ain’t broke…’ This is a highly concentrated formula so a little will go a long way. As it&r
				Just red your post again and it sounds like you want something like this.
				CarPro Reset - Intensive Car Shampoo
CarPro Reset Intensive Car Shampoo  CarPro Reset Shampoo is a car shampoo designed specifically to maintain Ceramic Sealants, such as CarPro CQuartz UK 3.0 by removing the dirt whilst not effecting the coating itself. CarPro Reset was formulated specifically for nano-technology based sealants and
