@Noxia that's pretty damn good.
I've had a set of the Army Painter "Wargamer" brushes for doing general painting/washes/metallics and they've lasted me a good amount of time with some care. For more detailed work I was gifted a set of Artis Opus Series S which are very nice quality, though they aren't cheap so they get extra care taken of them.<SNIP>
Any thoughts on brushes as seen so much mixed feedback there?
GW have made some crazy decisions over the years, but moving their list builder app behind a paywall has to rate as one of the worse.
What apps are you guys using that are 10th edition compatible?
Stating obvious here but they are very green.
Yep, I like the Orks in a bold almost cartoony colour palette, I think it undersells the lunacy of the Orks when they're in quite muted greens
Saw a rainbow scheme that actually wasn't as bad as it sounds.
Do not leave them sat in water for long periods.I've had a set of the Army Painter "Wargamer" brushes for doing general painting/washes/metallics and they've lasted me a good amount of time with some care. For more detailed work I was gifted a set of Artis Opus Series S which are very nice quality, though they aren't cheap so they get extra care taken of them.
I'm also pretty old school with my technique and use a lot of drybrushing, for that i've just got a set of makeup brushes which do a great job.
Why'd the green end up like that?Wanted to try something. It didn't work. I cried.
Black and white undercoat should give a glowing effect but I used the wrong brush. It was impatience too.
I'll try again later today or maybe tomorrow.
