i got one very similar
prepare for spray back into your face![]()
Worst detailing product I ever bought. Little protective nipple came off the end first use.
I use a noodle mitt for the wheels. I don't see the need for a brush just for the wheel face.
That's all I have ever used last 3 years & my alloys are pristine no brush scratches at all...those brushes scratch the alloy somewhere for sure!I gave up on most brushes for anything other than getting to the barrel - now use this - https://www.halfords.com/motoring/c...g/halfords-microfibre-wheel-glove-191373.html
https://www.cleanyourcar.co.uk/gtechniq-c4-permanent-trim-restorer is supposed to be one of the only "permanent" restorers for black plastic, other "back to black" style products are essentially just dressing that needs to be reapplied regularly.What's the best product to return black plastics (exterior) back to black? The Fenders (sorry. It's American!) have faded a lot and i'd like to restore them. Same on the hard top roof.
Before resorting to specialist vinyl paint - I'd try giving it a good scrub with some APC or Interior cleaner, and a nail brush - I suspect a lot of it's just long term grime sat in the textureWhat's the best product to re-paint interior plastics? I bought this on Ebay, but it's pretty tatty. Could do with a decent clean/paint
I'd say keep them topped with a spray wax. That helps loads.Good point
Come to think of it
Noodle mitt Vs wheel brush
Well, I guess the brush is good for when the wheels get really bad as they are the lowest part of the car, and for brake dust. So really hard to shift stuff if you don't keep onto of the cleaning
That's half the fun isn't it? Jump in a nice clean car ready for a road trip.I've got a 200 mile trip to Cornwall tomorrow , a week down there .... I know when I get back the car will be filthy, some rain forecast, but I still have a massive itch to go away in a sparkling clean car ... Do you bother washing before decent length trip away ??
Must resist ....maybe
