 - 25 Mar 2004
 - Fareham
I'm really struggling to progress due to getting pounded in battles and I'm not sure if I'm taking on the the difficult encounters too soon. Are any of you using a decent guide / walkthrough?
Not needed one yet really, can usually work something out.
Make sure you use your short rests between fights to heal people up, and before big/difficult fights make sure you've used the long rest to restore spell slots. Short rests can also restore some abilities such as Laezels adrenaline surge that lets her attack 4 times in a turn!
If you have Shadowheart as your main healer, you can re-spec her into a more useful sub-class of the Cleric than trickery domain. If you want some extra damage then go war domain or tempest, if you want better healing go life domain.
Shadowheart can cast the Aid spell on your whole party which can boost the max HP of everyone, I highly recommend doing this after each long rest, makes a big difference to your survival, especially as you can up-cast it to a higher level for additional boost to extra HP.
