Any news on 7800 xt?
A lot of the time the cooling performance / noise just comes down to how aggressively the default fan curves are set to in the Vbios.
large picture mode i think you're right, up to a point, a better cooler can still help with temps and noise, i mean i was looking at a Gainward 4070, 83c at 36db with 195 watts, compare that to my MSI 2070 Super Gaming X which is a card twice the weight at 1.5KG: 71c at 31db with 220 watts, a very clear difference in cooling performance.
And you can still buy cards with just plain bad coolers on them.
I think I might hold out for a 6950XT at close to £500 rather than a 7800XT at around the same price. Worse case scenario is I wait and the 6950XT doesn't drop down that low again and by that point the hype for the 7800XT will have died down a bit and there will be hopefully better discounts.
never actually tried it(mobile version), was hard enough to get the desktop version for me, saving pocket money etc :D how was it compared to the mx?
I never actually compared the two directly but most laptops didn't have a dedicated card,so you could actually run some games on it.
The MX440 was a stop-gap and got quickly replaced by a 9500 PRO!
ah fair enough, i went from an mx440 to a 5200 and that was pretty much a downgrade, you did better than me
