Is there any benefit to me using KomboStrike ?
CPU was installed yesterday, temps are bang on what they should be... around 40c idle, 77c max load cinebench, 60c max when gaming on GTA5
MSI afterburner and NZXT shows the boost going to 4450Mhz
Thanks![]()
It reduces power usage, lowers temps, increase benchmark score
I do it more for lowering power and temp further
OK just set mine to Kombo Strike 3
Idle temps are about the same, under full load - about the same temps too.
Only difference I can see, if I run a cinebench test rather than the cores going to 4.2ghz, they all go to 4.45ghz ( according to ryzen master )
Are you sure all cores are -30 , because on my board MSI x570 unify kombo strike doesn't do anything, I have to go to another setting pbo and set all cores to negative 30
You can download program called pbo tuner to confirm if all are set -30
I would say so give or take a few hundred points.First score 14257
Second score 14289
Third score, after closing every app except anti-virus... 14815.
Is that about right ?
	Seriously, don't worry about it.
As long as your temps are under 90 when running something like Cinebench then you're fine.
Gaming won't stress your CPU cores like Cinebench will so if temps are ok with that then stop monitoring and enjoy using your system.
Yeah I realise I was being a bit over the top there. So far so good with the CPU.
Glad I bought it over a 5800x for example as in Starfield the X3D outperforms it ( according to benchmarks found on this forum )
Even if it isn't, better 1% lows will ensure a much smoother gaming experience.Most Games the X3D is faster
finally ordered mine! accidently purchased a 6900xt a couple of weeks ago so that reduced the funds a little...
any particular software i should be running? currently on a 3700x and using ryzen master and process lasso. just want to make sure there are no conflicts going on when i install.
If you have an MSI board just set Kombo Strike 3, check all cores are running at 4450Mhz as above and away you gofinally ordered mine! accidently purchased a 6900xt a couple of weeks ago so that reduced the funds a little...
I have an MSI board, Kombo Strike 3 caused a hard system power down playing Warzone 2.If you have an MSI board just set Kombo Strike 3, check all cores are running at 4450Mhz as above and away you go![]()
