No this is why you just turn RT/PT off. Things might change when a £500 GPU can get the performance required. And/or when developers start working with it at the beginning of their project not at the end.And this is why you don't "upgrade" from ampere to rdna 3 if you care about ray tracing folks:
AMD need to get their act together asap on ray/path tracing. Not only are they now 3-4 years behind on ray tracing performance but they are also now significantly behind in ray tracing IQ. And before people bang on about:
- it's just one game that has dlss 3.5/RR - look at history, you know this won't be the case for very long
- RR can only be used with path tracing, nvidia have already stated they are working on bringing it to just normal ray tracing too and chances are, it will be backported to all the currents game using dlss and ray tracing. I also wouldn't be surprised if it somehow gets modded in (we all heard frame gen and dlss wouldn't be possible, well puredark etc. have proved it is)
I do hope there is a good ray reconstruction solution for all at some point though as this kind of thing will actually end up making RT very much a nvidia only thing if it gets widely adopted/implemented i.e. with rdna 3, it was usable/passable but as of right now, this whole thing is just further cementing nvidia as being the only choice if you value ray tracing.
4060 beating the amd flagship, cant be right......
No surprise there, 3.5 RR only works with pathtracing, NV's ruthless-AMD's just collateral damage when you introduce and design proprietary software to destroy your previous gen gpus.4060 beating the amd flagship, cant be right......
 Nvidia are a necessary evil to keep pushing us into the future.No this is why you just turn RT/PT off. Things might change when a £500 GPU can get the performance required. And/or when developers start working with it at the beginning of their project not at the end.
The future will be AMD and intel APUs if GPU pricing keep rising at their current rate.If amd had more marketshare and nvidia weren't about, we would be stuck in 2d gamingNvidia are a necessary evil to keep pushing us into the future.
I have an ampere GPU it just cant do RT either. And your 3080 is just about holding in if you like low fps. Maybe we should all subscribe to cloud gaming??If amd had more marketshare and nvidia weren't about, we would be stuck in 2d gamingNvidia are a necessary evil to keep pushing us into the future.
That's great and all but if you want to enjoy ray tracing, you ain't got a choice.
Well you joke but reality is that may end up being the path many will have to take.I have an ampere GPU it just cant do RT either. And your 3080 is just about holding in if you like low fps. Maybe we should all subscribe to cloud gaming??
This video really does a good job showing how much better reflections are in motion
The reflections in motion are so damn good with dlss performance now:
That was probably my only main complaint with ray tracing and it's reflections especially when using lower dlss/upscaling presets.
Anyway, enough of dicking about on a peasant 3080, shall be playing on the £18 4080 this weekend![]()
Going to try this on my RTX3060TI - maybe it will run OK at 720p!![]()
And what exactly is your criteria for 2d gaming, as 3d games date back to the 80s, long before nvidia was around...
Or GeForce Now apparently![]()
				TBH, it's kind of crazy when you think of it, netflix is what £16 for the best package? And it's a pile of crap with the content there, not to mention, it's not exactly requiring the same level of processing power that you would need compared to cloud gaming.
£18 well spent, all the savings that will be made to fund the 5080/5090![]()
NVIDIA DLSS 3.5 Ray Reconstruction Review - Better Than Native
NVIDIA DLSS 3.5 launches today, supporting GeForce 20 and newer. The new algorithm improves the looks ray traced lighting, reflections, shadows and more. In our DLSS 3.5 Ray Reconstruction review we test image quality, but also discovered that VRAM usage actually goes down and performance goes up.www.techpowerup.com
Ray reconstruction also dropping vram usage.
£18 today...
Wait until more and more people jump on. Won't be long it will be £25, then £30!
You will the say yeah, but a RTX 6080 costs £1500, so £30 a month is a bargain!!
 Not to mention, can cancel and reactivate for when new/better games come along so won't always be paying £18 every month.Imagine the manual approach with denoisers was causing some overhead?Very interesting. I can't think of a reason why though
Haha well yeah that is the case with everything really.
Either way, as it is right now, I'll take the saving being made![]()
