That’s a chunky updateI downloaded a 27gb update to cs2 yesterday but when I logged in this evening I had another 1.7gb download.
I had a check this evening and I was getting a solid 157fps in game and 120fps on the main menu.What FPS are people getting since release?
I've just got a new monitor (3440x1440) and only seem to be getting 170-200FPS, where on my old monitor 2160x1440 I was getting 350-400fps. GPU is a 4090 so I don't think i'd expect that much of a dip![]()
I couldn't see a way to cap the fps. Mine is at 1440p and high settings and occasionally get over 300.I had a check this evening and I was getting a solid 157fps in game and 120fps on the main menu.
Fps is capped due to having a 165hz monitor at 1440P
I'll see if I can remove the fps cap and see what I get
I have mine capped through the Nvidia control panel but the game also said 165hz under refresh rate.I couldn't see a way to cap the fps. Mine is at 1440p and high settings and occasionally get over 300.
fps_max in the console will cap the FPS. fps_max 0 will uncap it.I couldn't see a way to cap the fps. Mine is at 1440p and high settings and occasionally get over 300.
I have a 165hz screen too but the game just has an unclickable refresh rate bit in options with no value. I'm on fullscreen windowed.I have mine capped through the Nvidia control panel but the game also said 165hz under refresh rate.
Maybe worth checking if you have it on fullscreen or fullscreen windowed as mine was set to this to start with
Also just had another 1.4GB download this morning
Try in Full screen, windowed usually has issues with refresh ratesI have a 165hz screen too but the game just has an unclickable refresh rate bit in options with no value. I'm on fullscreen windowed.
I always game in full screen windowed as use my second screen quite a lot when gaming. I might try setting to the highest settings and see what my fps is like.Try in Full screen, windowed usually has issues with refresh rates
What GPU are you using?I have a 165hz screen too but the game just has an unclickable refresh rate bit in options with no value. I'm on fullscreen windowed.
3070ti.What GPU are you using?
On mine I can click it and adjust it lower if I want.
I have just checked when in fullscreen windowed the refresh rate is greyed out along with the screen res etc.
Seems like this only works under fullscreen
Have you set the max FPS via the Nvidia control panel under the 3D settings?3070ti.
Hitting the 394fps barrier as with CS:GO, 1440p highest settings defaulted with 4xAF and performance on the other setting. 4070/5700xWhat FPS are people getting since release?
I've only played it on Linux Mint btw, but I'm sure you'd have better performance with windows as you can use the Reflex stuff?Will need to check my settings when i'm next on then, something must not be quite right!
You sat in a queue for over 45 minutes? wild.This is almost unplayable now, I'm in queue longer than matches last.
