You’ve contradicted yourself here.licensing they would need to work with but given that dlss is free and nothing is required from Nvidia to get the go ahead
The licensing agreement stipulates what Nvidia require.
Working in the software development industry, the only thing I can think of that would cause them to take longer is any contracts, licensing they would need to work with but given that dlss is free and nothing is required from Nvidia to get the go ahead (and amd have stated there is nothing blocking Bethesda from implementing dlss). From a technical pov, there is zero reason why they couldn't implement this very quickly especially since the game has motion vectors and fsr 2 thus means implementation of dlss would be less than 2 days (and amds own pr articles show this too).
The only thing that would take longer is going through QA/testing to ensure it doesn't break anything but this is Bethesda, not exactly their strong point....
Yes, I selectively quoted the part where you contradict yourself. The additional context doesn't make it any less of a contradiction.Selective quoting.....
Read the full post:
If anyone cares enough, have a read through nvidias terms and conditions here:
Either something is required or nothing is required. It cannot be both.
They are putting it in the game. Get over it.
Even in your explaination you ignore the elephant in the room.Well then you aren't comprehending the post, the key bit being this:
Which I then go further on to state based on what we know, "licensing/contract" should not be an issue because:
- dlss is free to implement and to my knowledge nothing is required from the developers to start using it thus from a technical pov there is no blockers on this front
- amd have stated there is nothing stopping bethsada to implement dlss i.e. nothing in amd or Bethesda contract that would block the implementation of dlss
Is just false. unless you're implying that the DLSS License was not written by Nvidia.nothing is required from Nvidia
DLSS has a license, which stipulates the terms and conditions for its use. A fact that you seem to want to ignore. Therefore the notion that
Something is required and it is in the license agreement.
Like I said earlier in this thread, if you use only fg, what AMD call "native AA" then its fine because you're running native image quality, tbh if you need to more than double your frame rates then you should probably be thinking about more powerful hardware.DLSS 3.5 has deffo got a lot better, hopefully by 4.0 that will be great tbh because at moment there too many issues. AMDs Fluid Motion has even more issues with it and looks much worse overall. Can only hope when they get FSR4 they will have got better handling on it.
With that said both have done a lot better than I expected them to do but they don't match to Native and proper frames still.
Anything new on FSR3 testing yet then?
It's not clear but I think there might still be a small difference due to a difference in AA methods applied between default and FSR even though you select native AA.Like I said earlier in this thread, if you use only fg, what AMD call "native AA" then its fine because you're running native image quality, tbh if you need to more than double your frame rates then you should probably be thinking about more powerful hardware.
Amd scoring an own goal again, shockerNot that I know. Would have been loads of content out there had AMD released properly. Wonder why they did not give reviewers and youtube guys a early preview with an embargo to create excitement and much bigger coverage?
Even seemingly pro AMD outlets like HUB are not impressed with how it was all done.
By far the best person to test out this stuff given he was the only one who identified the issue with input lag issue on nvidias frame generation when you were hitting the screen max refresh rate.Because both games were essentially rubbish it's possible they just got it in as a first release to solve issues before hyping up an actual game people play.Not that I know. Would have been loads of content out there had AMD released properly. Wonder why they did not give reviewers and youtube guys a early preview with an embargo to create excitement and much bigger coverage?
If you can link me something from nvidias dlss terms and conditions that would cause a delay in the implementation of dlss then feel free to post it here as that would actually be worthy of discussing....... As of right now, all you're doing is making a mountain out of a mole hill by the usual of selective quoting to fit your narrative. I have already stated openly in my op, the only thing that would cause a delay is something to do with their licensing and contract but given the stated "facts" so far, I don't see what there could be?
Edit:
The only thing is what stooeh said, you would need to credit Nvidia somewhere to show the use of their tech. I can't imagine this being a huge pain to do.... Unless amd didn't want that.... but then amd have stated there is nothing stopping bethsada from implementing dlss.
the only testing i have seen so far is with up scaling enabled, inevitably they all point to temporal shimmering, apart from that one Star Citizen one where he's just using fg.It's not clear but I think there might still be a small difference due to a difference in AA methods applied between default and FSR even though you select native AA.
Haven't seen enough testing yet and both games are crap so have no interest in them.
But this is how it supposed to work and how Nvidia FG works.At the moment it just looks like the illusion higher frame rates to smooth motion with little to no improvement over how the games feels when moving controls etc.
Star citizen would just be using the AFMF driver level implementation though?the only testing i have seen so far is with up scaling enabled, inevitably they all point to temporal shimmering, apart from that one Star Citizen one where he's just using fg.
Star Citizen uses Temporal AA for its true purpose, as its default AA and it has temporal shimmering, like where foliage meets water, as well as some high speed trail ghosting, thought its not that noticeable and improving all the time, and very long distance volumetric clouds, that actually can be very noticeable, which they have acknowledged and are actively working on it.
so i'm not sure people in SC would notice it anyway but he did not test anything that shows up those TAA issues.
