- 19 Jan 2021
Better than DLSS? Cooking dinner at the mo.Anyone using Intels XeSS? The image quality is actually insane
Also Cyberpunk 2077's Biggest Mystery May Finally Have Been Solved!
Yea mate better than DLSS! I'm just heading out so won't be able to run more testing until tomorrow but I see there is a 1.2 dll that may also improve furtherBetter than DLSS? Cooking dinner at the mo.
Where there's a claim, there's an IMGsli to verifyAnyone using Intels XeSS? The image quality is actually insane
I've made an important discovery, can anyone else check this? When running at a DLDSR resolution, VRR does not work. Drop back to the display resolution and all is well. This is observed whether DLSS/Frame Gen etc are on or off, so it's specifically something to do with using DLDSR where VRR isn't working.
I checked VRR activity by enabling the refresh rate overlay on my monitor which changes in realtime when VRR is working away.
Tried to verify this and according to my OSD my monitor is fixed @ 144Hz, yet there is absolutely no screen tearing in any image even when I push my gpu to its limits and it chugging along at 30Hz. Nvidea CP says GSync enabledI've made an important discovery, can anyone else check this? When running at a DLDSR resolution, VRR does not work. Drop back to the display resolution and all is well. This is observed whether DLSS/Frame Gen etc are on or off, so it's specifically something to do with using DLDSR where VRR isn't working.
I had started to see that. That makes sense. Thanks. Grabbing that mod too.The level required now scales with your character level in 2.0. For example being able to push a dumpster out of the way used to require 6 body at any level. Now if you're say level 10 it'll be 6 body but if you're level 11 it'll be 7 body, level 12 and 8 body etc. At level 5 I could fix my own car or talk to someone about theirs. At level 10 though I've forgotten how to repair my car, as the check requires a higher level.
I've been having the same problem. After a google it appears to not be a new problem. I've never had it in my previous (multiple) playthroughs.Oh the game also is really laggy for a short moment when I come out of the menu
Cyberpunk runs in windowed mode, I'm betting it would work if you changed ur desktop res to same as DLDSR and then run the gameI've made an important discovery, can anyone else check this? When running at a DLDSR resolution, VRR does not work. Drop back to the display resolution and all is well. This is observed whether DLSS/Frame Gen etc are on or off, so it's specifically something to do with using DLDSR where VRR isn't working.
Claim
XeSS Ultra Quality is softer than DLSS with the same default 0.5 sharpness setting, and it has a 30fps hit! And that was with Frame Gen enabled on both! Also you can't use Ray Reconstruction when using XeSS as it requires DLSS![]()
No idea if true but am I detecting a hint of nvidia 4090/DLSS defensiveness here chaps? HahaCalling ******** on this. Not better image quality, and has a 10fps deficit in a like for like test I ran.
Its not. Its simply the patch broke mods and it takes a few days for them to be upgraded.
It's late and I can't be bothered to explain that it does in fact run in windowed mode regardless of in game fullscreen or windowed options. Enable your g sync indicator in NVCP and change your desktop res to same as DLDSR res and watch VRR kick inIt doesn't run in windowed mode when you set the mode to full screen in game, in windowed mode you cannot choose a DLDSR resolution for starters, only when set to full screen mode does that become available. Also when you alt tab or press winkey, the game minimises instead of staying on screen but in the BG behind the alt tabbed window - Another indicator that confirms that it is or isn't in an exclusive fulscreen mode![]()
I'm assuming this is your first time playing after this weeks patch?Yup just gone to play - my game is now broken. Uninstalled all mods (only had a couple anyway). Cant launch after update. Also seeing people on xbox saying patch broke their game too, others saying their saves are now corrupted.
Just tried it, it's much faff as you have to change desktop res through NVCP else Windows wants to enforce 60Hz but anyway, you're right the game then triggers VRR in DLDSR. Weird how no other game operates this way.It's late and I can't be bothered to explain that it does in fact run in windowed mode regardless of in game fullscreen or windowed options. Enable your g sync indicator in NVCP and change your desktop res to same as DLDSR res and watch VRR kick in
Obviously need more vramA 4090 simply isn;t powerful enough to have decent input latency at 5160x2160.
