- 28 Dec 2017
- Beds
Generally those things can close up if you do them up all the way. And then if you slowly loosen, it should adjust the spray pattern.
Silly question probably but do you then rewash these and use again or would a washing machine wash wreck them?
Chucking some vinegar in instead of Fabric Softener isn't a bad idea. Stops them getting stiff due to any soap and hard water, but doesn't clog them up. White vinegar that is.They are Machine Washable - I’ve not put these through numerous washes yet but after a couple of washes appear like new.
I tend to wash my car towels at 20c using Non Bio Liquid Detergent and without any Fabric Softener as this ruins towels absorption.
Liquid soap + white vinegar, along with water softening tablets is my go to combo for washing car towels![]()
The softening tablets are doing the same thing as the vinegar is in this case, so just use whichever is cheaper.
I'm not allowed to put rags through, manual wash for me
Rinse them through with water, then I've got car pro microfiber wash
Does not come out as clean though![]()
Still beading like a champ. Last wash was 3 weeks ago and ~450 miles.
Certainly. Them love beads tell the whole storyLooking good! You can always see those who look after their cars and those who don’t as the select few of us have lovely beadage
Edit: Perhaps well maintained is better to describe it.
agree - 60c bio washes, too, to shift product solvents/residue, like for oily boiler suit for diy underneath car - regular clothes only get non-bio 30C,No they never have the same level of clean/softness again :/
Forgive me for being stupid, do you use these to dry your paintwork?
