NVIDIA 4000 Series
So the 4090 gaming of I have (rev 1.1) deffo has quite fans but noticeable coil whine, more so than the Aorus Master *sigh*
Can I just please buy a card that isn’t poo!
Gaming OC or Gaming Trio? Either way I know that feeling lol.
A expensive case won't give you a better gaming experience or make the PC perform noticeably better though.
indeed, though generally referring to the contradiction of spending huge on a gpu but as the poster said, to keep budget down, if you can afford 1.6k for a gpu why would you keep budget down :p
That's some bad luck to get coil whine on a Gigabyte, they are generally the best. Msi and Asus have quieter fans though. Pick your poison lol.
Yea the Gigabyte Aorus Master I had featured no coil whine but had an iffy fan.
I gather the 1.1 revision Gaming OC is more susceptible to whine than the original… it’s a lot more noticeable than the Aorus.
Bah.
I have a little whine with both of my 3070s in Windows 10, but not in Windows 7 strangely - not sure why. Though either I've got used to it or it has quietened down as I've not noticed it in awhile but it was fairly slight - trying to replicate it just then I had to stick my head in the case to notice it at all.
Other than that I've not really had any whine with any of my GPUs except uncapped framerate in the simple graphics.
EDIT: After 2-3 years of use or so it seems to have mostly quietened down on my 3070s I can't replicate it like when they were new - I'd pretty much stopped noticing it after a month or two anyhow - not sure if that was due to it reducing with some use or me tuning it out.
Apparently the 4070, 4070 Ti and 4080 are getting SUPER variants.
Apparently with a huge price slash to go with it.
4080 Super $799
4070 Ti Super $599
4070 Super $449
And then you wake up :cry:
It will if you overclock the case!!!
:p
I imagine it's to spend the rest on like 10-20 games? Not a bad shout TBF?
I bought a cheap case but from an old OG case brand that was very good on temps and simply upgraded the fans.
Because the idea of spending £30 each on fans is laughable imho, so I chose the most mesh asf case, without paying for a scene tax brand...
Then I simply took out the stock fans it came with and put some near silent BeQuiet's in that cost me a tenner each and my cpu/undervolted gpu never goes above 53-64C despite being next to an airing cupboard and I cannot even hear my system!
The BeQuiet case fans are on the lowest power you can run through them with PWM disabled and no need for watercooling or it's additional costs...
It lives under the desk and is an all black on black no rgb build inside and out with just full mesh front/top so even if I wanted to see it I couldn't haha! It cost me £85 all in with the fans in the end as customer service sent me my 3rd fan for free :) Win Win?
It comes in black or white as well, some pics below, btw this isn't my build, merely specs and some reviewer pics of what it looks like with the stock rgb fans, but gives you a good idea... As you can see it's very good for airflow/supports all the fans/rad's you'd need/massive cpu hsf, and a 7900xtx/4090 as long as you buy the right brand/model :) Not bad for £65 imho...
Easy way to find out, @mrk how's the fans on yours?
That'll easily debunk bs you read in 'reviews'...
Edit*
The Zotac fans, my card is the Trinity non-OC 4090, fans seem fine in normal mode, audible when gaming but not obscene like some, in the quiet VBIOS fan mode it's essentially silent.
Oh yeah I misread and edited the post, no coil whine to speak of on my card. The PSU can affect coil whine variables too, I have a HX1000i for reference.
