- 1 Mar 2019
Okay will do. sorry yeah the 2 eps plugs share the same slots on the back of the PSU as the PCI-E its just on the device end they are different, the issue is there are 6 of those but I need a 7th basically for the Icue link hub.I'd suggest starting a new thread and posting a diagram of what you've got connected where, as I'm not sure why you'd need to use a PCI-E power plug for your motherboard when the HX1000 has 2x EPS 8 pin plugs, and 8x PCI-E plugs?
If you must use adapters, then 2xmolex to 6 pin are the better option as they're normally better constructed and the connectors can cope with more load.
I did also consider molex as max output is higher but seen some people say stay well away from them for fire risk.
