- 30 Mar 2017
So, not sure if anyone else encountered this issue with Cablemod early version of the 12HVPWR cable. The one attached is a direct replacement cable for ASUS PSUs.
I noticed they removed all the early version cables from their shop not long after I installed the attached.
I bought this in July and not long after started having black screen issues. I also made a few other component changes so wasn't initially aware that apparently there may be a cable issue.
Using an RTX 4090 FE.
Was obviously aware of the reviews for 12HVPWR in general and having issues with melting etc. etc.
Just got my replacement "stealthsense" cable. Narrowed the issues down to an Event 41 critical error usually following a nvlddmkm error.
Fingers crossed this sorts it!
Old cable:
Old cable:
