- 17 Jan 2007
- Nottinghamshire
Still the sameAm going to disable my AMP profile in BIOS settings to see if that helps
If you reset all BIOS settings to default temporarily does that make any difference? Are you monitoring CPU temperatures and clockspeeds? If you run a Cinebench CPU multicore test we can see whether it's performing correctly.Still the same
CPU temp is a little high due to the fact I'm still using the original AMD Prism cooler which came with my old 3700x. Have ran Cinebench and performed correctly All BIOS settings appear to be correct and defaulted. I'm starting to think maybe FS2020 is corrupted so maybe have to reinstallIf you reset all BIOS settings to default temporarily does that make any difference? Are you monitoring CPU temperatures and clockspeeds? If you run a Cinebench CPU multicore test we can see whether it's performing correctly.
CPU temp is a little high due to the fact I'm still using the original AMD Prism cooler which came with my old 3700x. Have ran Cinebench and performed correctly All BIOS settings appear to be correct and defaulted. I'm starting to think maybe FS2020 is corrupted so maybe have to reinstall![]()
I suspected that which is why I ordered Thermalright Peerless Assassin 120 SE ARGB - Thanks to PhatboyI don't think that cooler is up to the task of cooling this CPU.
Just hope it fitsThat's a great cooler, better than the NH-D15 in raw performance according to Gamers Nexus (it's a much newer design) and very cheap.
I did this as I had a buyer for my 5800x. Cannot see what res you game at but for me. The minimums where much better and depending on the game some were higher others it made no difference.As a computer used simply for gaming, I’m thinking of doing this too. Coming from a 5800x.
Paired with a 3080Ti, I’m not thinking of the moar frames(!!), but like the idea of lesser stalls, latency, etc. Not that I suffer from them too much, but less is always better.
Plus it’s the last Hazaa from AM4 in a sense.
I have 5800x and I am looking at a last up grade for my AMD4 motherboard to go for 5800x3d or CPU with more cores.
Will I see any real benefits from the upgrade or best to save the money for a AMD5 system?
It’s going to depend on you needs. If it’s for gaming and you have a mid range GPU or above, then you will see a benefit.
I actually just switched out a 3700X for a 5800X3D while running a 4070. The uplift in some games has been huge, Dying Light 2 for example loved the change.
Sold the 3700X for £70, easy drop in upgrade, I have zero regrets.
The amount of people I know running 3000 series or equivalent chips on 3090's or similar is staggering, granted it depends on the resolution but there's a lot of performance to be had.
I have a 7900XTX, I do game if I was coming from a lower CPU I would not be hesitating but I had my 5800x for almost three years now.
Saw similar (I don’t have a 4090) going from a 5800x3d to the 7900x3d.I went from a 5900X to a 7900X3D but also tested an 5800X3D in games at 4K on an RTX4080. Most graphically intensive games like CP2077 saw no real improvement but CPU limited games like MSFS saw a massive improvement.
5900X = 43 FPS average in MSFS
5800X3D = 60 FPS average in MSFS
7900X3D = 70 FPS average in MSFS
All identical settings and flight (New York Cesna sight seeing) same RTX 4080.
Like some other here, I went to the 5800x3d from a non 3D. The difference for me back than was mixed mainly due to more production type work I was doing back then.
With that all said, the 5800x3d was a great CPU for AM4. Should have saved a tonne of money and stuck with it.
