- 26 Dec 2003
- Cambs UK
I'm in pretty much the same position as you, just started playing. If you have a 2k/3k series Nvidia card then the frame gen mod is really worth it for free fps. It's not really a mod as such, so totally worth it on your first play through.I finally started playing this over the Christmas break, only a few hours in, have done a few side missions and explored the city a bit, my next main quest is The Heist - still early days but I'm really liking it so far.
Will finish the play through before I start playing with Mods though.
Enable Frame Gen on 3000 series cards - Such as The Witcher 3
Frame Gen goodness on your 2000/3000 series RTX! Games such as Alan Wake 2, Cyberpunk, Ratchet and Clank, The Witcher 3 and many more UPDATE AS OF 24TH DECEMBER LukeFZ's AMD FSR 3 Mod To Enable Frame Generation Across All FSR 2 Games Has Been Leaked LukeFZ's AMD FSR 3 Mod To Enable Frame...
and after watching the vid in @mrk's post a few up https://forums.overclockers.co.uk/threads/cyberpunk-2077.18408690/post-36881407
I decided to add all the mods listed in the vid and use similar settings to the vid and it looks great and runs great (still get AI bugs though),
