Deleted User 298457
Deleted User 298457
OP
For sure but I have no idea what lights are available for such an install.You may as well just get an electrician in then, its in zone 1 and you'll need to notify.
I would think sealed units in such a space not GU10s.For sure but I have no idea what lights are available for such an install.
Is this for the cieling?Further Qs please gents...
Is this OK to go between the joists?
They do the "32" version which is better but a lot more expensive as I'd need 3 packs.Rockwool 37 Cavity Batt Thermal Insulation Slab - 100 x 455 x 1200mm | Wickes.co.uk
Rockwool 37 Cavity Batt Thermal Insulation Slab - 100 x 455 x 1200mmwww.wickes.co.uk
And what lights would people suggest in a bathroom? I'd like them dimmable - so I am thinking Hue/smart lights?
And what lights work in a niche?
I don't even have a towel radiator and my towels are bone dry when I use it and sometimes I have two showers a day!I would definitely add an electric element to my towel rail if they weren't £60 aka gas wasn't so cheap. Our heating used to come on in the morning to take the edge off, but it was off by the time we'd both showered. Therefore, the towels weren't drying. I ended up doing a sort of artificial bit of heating around 9 AM bringing upstairs to 21C just to get the towels dry! Soggy winter towels are disgusting.
The floor between bathroom and downstairs. A bit overhangs the porch so is fully exposedIs this for the cieling?
Is 22mm enough to drive the bath, basin taps and toilet?
O OK. You don't need to insulate the 1st floor really. That's what I have heard of and researched.The floor between bathroom and downstairs. A bit overhangs the porch so is fully exposed
I can do 22mm from the top so I guess I'd get some benefit. Not sure these modern bath fillers can cope with the flow but we shall see!Yeah you wouldn't be using all three at the same time. Only gonna make much difference if you have 22mm coming all the way from the source though.
I thought that until I saw the obvious pattern: Start bath running, sit on toilet. Finish up, flush, start washing hands - all 3 supplies in use. My bath tap drops right off for a little bit when I do this as we've poor flow.Yeah you wouldn't be using all three at the same time. Only gonna make much difference if you have 22mm coming all the way from the source though.
Some of his 1st floor overhangs the porch so it's effectively an exterior wall.O OK. You don't need to insulate the 1st floor really. That's what I have heard of and researched.
It's mainly the ground floor that needs insulation
Ahh okI thought that until I saw the obvious pattern: Start bath running, sit on toilet. Finish up, flush, start washing hands - all 3 supplies in use. My bath tap drops right off for a little bit when I do this as we've poor flow.
I am debating putting some insulation plasterboard on the detached side of my house but I don't think I have enough room for it due to the staircase..Chaps,
May have dropped a clanger here. The insulated plasterboard I've bought is 38mm (25+12.5).
I'm not sure the back has a vapour barrier - at least, it isn't silver. I was planning on just glueing and whacking a few screws in.
Do I need to switch product or batten out?
Edit: false alarm it has a barrier!
and it was only two screws so can always come down.If you have the flow rate its not a problem though, I frequently use the toilet then wash my hands while the shower is running and it has zero effect on the shower...plus all my pipe runs are 15mm from the cylinder(less standing water and heat loss which is a plus).I thought that until I saw the obvious pattern: Start bath running, sit on toilet. Finish up, flush, start washing hands - all 3 supplies in use. My bath tap drops right off for a little bit when I do this as we've poor flow.
Oh snap....I hadn't considered that. My flow and pressure is great, so maybe I should downsize to 15mm!If you have the flow rate its not a problem though, I frequently use the toilet then wash my hands while the shower is running and it has zero effect on the shower...plus all my pipe runs are 15mm from the cylinder(less standing water and heat loss which is a plus).
Ill refrain from offering advice until tomorrow as I'm 3 sheeps(sic) to the wind lolOh snap....I hadn't considered that. My flow and pressure is great, so maybe I should downsize to 15mm!
I've 100 quid of 22mm still wrapped so sober up quickly in the AM
