If they have no planes left they can't be shot down by the F16s. Masterful.Russia in a hurry to use their air force before F-16s shows up?
That `frakensam` is either NASAMS or IRIS-T SL a; both are in use in Ukraine are are very effective.There's the frankenSam firing RIM-7 that should be out there now
Apart from missile failure, the other aspect that we won't know about is will the warhead actually go off.
Nuclear warheads require a lot of maintenance and proper storage conditions, its not something you can stick in a cupboard and pull it out 20 years later and expect it to work and a warhead that's stored in the wrong conditions could go from working to harmless in like 1 or 2 years, it can happen quite fast.
So even if these missiles were flawless, we won't know which country's have not being maintaining their warheads until the day comes to use it
Out of interest when you say 'spent a lot of money's was that in man hours, equipment or money spent on replacing perishable items?I spent 7 years working in this area and have first hand knowledge and experience. We spend a lot of time and money maintaining our warheads.
Those Duracell M3's are quite pricey!Swapping the AA batteries?
The Russians might be incompetent but…
Trident missile test fails for second time in a row
The UK's nuclear deterrent failed to fire a test missile reportedly landing close to the launch site.www.bbc.co.uk
This is on top of the carrier problems earlier in the year.
Time to get the chequebook out. You cannot defend on the cheap.
Do they ever test detonate a nuclear warhead? I don't know much about the subject, probably easier for me to read up but, I assume when they designed trident the warheads were aso designed for the missile or were they from an earlier design... Lots of questions. All a bit macabre a discussion probablyAll of the above. The whole purpose of the site is to support the Nuclear Deterrent, which revolves around the warheads. It is all specialist skills, tooling and materials.
Second time in a row that a test fire has failed from one of our boats though - and I expect people said the same thing back in 2016 when they covered up the failure (although it sounds like that failure mode was different so they may well have solved whatever problem caused that)...It’s also worth noting as the article mentions there have been 190 successful tests of the system. I’m sure there will be some quick action to identify the issue on this one though.
I know public statements aren't going to go into detail on topics like this, but this is a bad look and gives zero confidence - it reads like a face saving lie rather than a commitment to actually getting to the bottom of things.In a statement the Ministry of Defence admitted an anomaly had occurred in the most recent launch. But it also said that HMS Vanguard and its crew had been "proven fully capable" in their operations and the test had "reaffirmed the effectiveness of the UK's nuclear deterrent".
The statement added that Trident was the "most reliable weapons system in the world" having completed more than 190 successful tests.
Do they ever test detonate a nuclear warhead? I don't know much about the subject, probably easier for me to read up but, I assume when they designed trident the warheads were aso designed for the missile or were they from an earlier design... Lots of questions. All a bit macabre a discussion probably![]()
Floppy missile not launching, its the problem with old equipment, when its needed to perform it may end up as being incapable of a successful launch
We need some better military spec viagra![]()
