Playing or stocking up on screenshots and video captures?I've been playing for 7.5 hours![]()
Playing or stocking up on screenshots and video captures?![]()
The SSR is so bad in this gameShame they didn't at least add RT reflections as it somewhats brings the rest of the visuals down a notch.
I usually hate vignette but in this game, it seems the whole colour and art style was designed to have it turned on in this game so have left it on but turned off the other post processing effects.
Yeah the vignette balances the exposure outdoors and you no longer get the strong highlight overexposure, but like I mentioned, the vignette has a sharp cutoff which is visibly distracting a lot of the time and I wish this could be softened (not found a workaround yet).The SSR is so bad in this gameShame they didn't at least add RT reflections as it somewhats brings the rest of the visuals down a notch.
Seeing all these comments and the ubiquitous commentary, videos/screens from mrk makes me want to play the game over again on PC. One gripe I have with the game is that as you get further into the game there are far to many weapons/armour and what have you that you need to upgrade so you end up grinding a lot of materials, although this is usually offset by how beautiful the game looks and sounds.
Will give it a go. As that is one of my options that usually get turned off from the get go.
How is your 1080 handling it? No 5160x2160 for you I suppose?![]()
And yeah the SSR is more distracting the more time you spend around water, which I've discovered can be quite a bit given the number of caves and things to be found by going under water. One thing has been clear though, the more time you spend in the game the more the SSR and lack of accurate GI seems to become more obvious. See an occluded crevice in some rocks? Get too close to it and the occlusion turns into brightness for some reason as if suddenly there's light there, it's not HDR adaptation from the game engine, since only that occluded area loses the darkness. Such is the way with baked screen space shadows that aren't fully baked for all distances.
Still, on their own these can be mostly ignored I think.
Someome has modded it so HDR is fixed btw, for those that play in HDR![]()
You don't play this game in HDR? Lol
I don't mind the sharpness really, but will try with 0 later today when I jump back in
Sharpness at 5 is definetly oversharpening, 0 is much nicer on the eyes.
He doesn't, too much of a screenshot whore![]()
