Caporegime
- 7 Apr 2008
- Lorville - Hurston
Lol this is like version 10 of the UIHey now, they've only had 11 years to work on the UI, give them time!
I gave them moneys... what more could they possibly need??!!Hey now, they've only had 11 years to work on the UI, give them time!
I think most of it is pretty straight forward, I won't deny having a few moments of wondering what I was doing, the hardest parts for me were putting on the helmet after I had dropped it on the floor somehow and then finding the elevators to the hangar as the little guide thingy vanished. I then had a bit of a struggle going from the planet to the station as I couldn't get it to go so I cancelled the fast travel and started again and it worked fine second time.I'm impressed, I try the tutorial occassionally and try to be "fresh to the game" and follow it directly, I find I sometimes don't get pointed in the correct direction or get left not knowing the next step, it's OK but it could be better and it's sometimes a few patches behind before they update it. So credit for you actually getting to the stage of taking off!
If in doubt feel free to ask people on here to jump in with you, give you a taste of smashing into a station as a group, multicrew accidents are more fun![]()
What you mean replacing again? It is under the hood although in limited capacity with the amount of code re-written CryEngine.I keep wondering how much life their engine has left before it needs replacing again.
All in all I was quite taken by it for a very quick blast, I went to bed about 1.30am feeling like I can't wait for another go at it.
I did end up upside down after take off, took me a while to get back to being the right way around, I think I was trying to use WASD too much rather than the mouse.
You are on a better system than me as I only have the 7900xt paired with the 7800x3d, most of my settings were on medium, should I go for higher? What do you guys use for showing FPS, it was a little bit rough but I expected that with the warnings in here.
I thought they replaced the engine a few years back as it wasn't good enough?Like what? Whose engine are they going to pull to bits and completely rebuild to get all this to work now???? This technology doesn't exist outside of CIG offices.
They have basically re wrote the engine from scratchI thought they replaced the engine a few years back as it wasn't good enough?
SO I got deep into this a few years ago and had a really good time (outside of the optimisation). Not played for a while and have forgotten the controls, we have a tutorial now lol.
