- 19 Feb 2007
- Northampton
Bought the basic starter Aurora, May as well as it was only 20 quid
Check you've plenty of space on ALL of your drives so it's got space to unpack etc.Bunch of![]()
Got to the end of the download 99%, then said " Download failed ".. Remove files?
Only gives you an option of Yes or press X. Press X it restarts the download anyway for 13gb+!
THAT'S NOT how you do a download, ever heard of a verify files?![]()
See now the Aurora is awesome, cheap, muli-role and has a Quantum drive something more expensive shuttles don't..Bought the basic starter Aurora, May as well as it was only 20 quid
Although seems like it's something else, I had similar issues before I got fibre broadband and had to redownload the low (like all 100GB, took about 48 hours!)
Ahh so u are worzel!!! diddnt know who u was in ocukBeat you
LOL you can verify filesBunch of![]()
I have you all beat...
Funnily enough you still have the same amount of CPU cores as a 2013 cpu
But do you though?
Oh.... #### off, that makes you the grandaddy, how do you feel now???![]()
Do you have have another pc to try and install it on?No that doesn't work, it's that obvious... so no LOL
As soon as that error comes up, it deletes the files from the folder. I've checked this THREE times now
There's nothing to verify as the folder is empty
"This would be the final step, which is to basically remove everything and start over. Given the size of the game, this will take considerable time and thus trying other troubleshooting steps should be completed first."
Even did this and nope... Fails at halfway.
Seems to be a common issue, with people trying everything as much as reinstalling Windows for an alpha
Not bothered anymore though!
I thought I might have had have you beat, but we actually enlisted on the same day!But do you though?
