- 4 Aug 2007
- Wilds of suffolk
Dan
Are you going to build the walls as panels, if so I find a foot works wonders as a way to get stuff tight
Nails pull tight anyway, thats the point, easier to nail than to screw well.
Use a small/medium lump hammer and you can send some pretty meaty nails in with no drama at all.
When doing DIY and time is your friend I always clamp, you can get rid of some serious bending / warping with clamps
