- 2 May 2011
- Woking
Wheel would stay on, brakes would fall off!![]()
Hmm I'm less worried about that
Gave up, I'm sore. I'll ask the garage to free up those bolts when it goes for MOT retest.****ing brake caliper carrier bolts are good and seized on the front offside. The front is much rustier than the rears were.
Penetrating oil overnight and then smack the bolt head with a big hammer.Gave up, I'm sore. I'll ask the garage to free up those bolts when it goes for MOT retest.
Yep, been topping up the penetrating oil every couple of hours. I should buy some proper Plusgas though.Penetrating oil overnight and then smack the bolt head with a big hammer.
Then give it a go.
6 point socket not 12 point, breaker bar not ratchet. It'll come undone.
No room for a breaker bar without having a lift annoyingly. It's got to go to the garage tomorrow anyway.
Got a DCF921 but it wasn't having it, tried tightening a bit first etc... doesn't help I was on my drive and don't want to annoy the neighbours too much.Get some guns
That's a good idea actually! Might have a look tomorrow depending on timing.Not even with the steering at full lock?
Need heat broYep, been topping up the penetrating oil every couple of hours. I should buy some proper Plusgas though.
