Is that a tiny brake disc or really big wheels?Another fun friday/weekend job on the s...box.
14 inch wheels and tiny brake discs.Is that a tiny brake disc or really big wheels?
Tyre profile on the other hand is 60, if I remember correctly.DIY would be 1/4 of that cost.Big service on the M140i at BMW, sparks, oil and filter, air filter, micro filter, brake fluid… some 4yr car check. £622, ouch.
I would get the injectors checked, common failure and if overlooked can get expensive really quickly.
DIY would be 1/4 of that cost.I would get the injectors checked, common failure and if overlooked can get expensive really quickly.
Spark plugs are a bit of a faff tho..
Prep work for Stage 2, if I remember correctly.
I usually give the car in for a service if its under warranty, soon as its outside the warranty its DIY, I've a few mates with licenses to update the service history on the cloud. Usually pop around on a Friday with pizza and some beers.I know, I’m usually not adverse to oil, sparks, etc. even down to alternators and such. But it was my first ‘nice’ car and want to keep it fully BMW serviced. Don’t feel it’s old enough to lapse into self or random garage servicing yet… despite how potentially better and cheaper that could be!
gonna go back to black vac lines as well, red seemed like a good idea at the time.also did my spark plugs, i run coppers so quite used to doing this now!
I need to repaint the rocker cover/s but not sure on the colour, blacks a bit plaingonna go back to black vac lines as well, red seemed like a good idea at the time.
Copper core spark plugs, slightly better spark making them good for turbos with the tradeoff of not lasting, but they are cheap as chips.What does running coppers mean?
The guy at the dealer scuffed it on a display cabinet carrying it to my car, and then I dropped it on the groundAfter being royally raped on a £1000 service from Audi (including over £100 for a pollen filter I can buy online £30), I then proceeded to rip the clamps off the engine cover because I forget it was clamped down
I wanted to check if they had replaced/tightened the air filter. Turns out it doesn't get replaced until 90,000 km or 6 years! Anyway, expensive mistake on my part...
New engine cover ordered - £300!!!! FML.
(I was on a tight schedule before the trip!)I had a B service done the other week and they only inspected the air filter instead of replacing it, car has only done 5714 miles and is just over 5 years old. In fact the air filter isn’t even on the service checklist at all.I wanted to check if they had replaced/tightened the air filter. Turns out it doesn't get replaced until 90,000 km or 6 years! Anyway, expensive mistake on my part...
