I can get convenience factor and their returns policy (to note this doesn’t apply to things bought from 3rd party sellers as amazons support is getting more and more robust as pushing you off to the 3rd party unless you kick up a bit of a stink) but lowest price isn’t a notion I can get behind.
I just don’t find Amazon to actually be cheaper for anything I buy, at best it’s price matched.
Products can usually be found elsewhere for the same price or less. As you need to go around the houses to check pricing anyway, it’s not any more convenient to buy from Amazon as you’ve already done the hard work.
. One thing about ebay is that it's a pain if you need to return something, one thing I'll give Amazon is their return policy is quite good
