Maybe somewhere around a 50% increase over last gen ?
Only if your are including NPU performance in that figure.
No, they're not even launching with the boards.
From what I'm aware of, the only confirmed information is that the X Chips launch in July and the boards in September.
They're coming, just a question of when.Is there even new ones coming out to replace these ?![]()
when AMD announced its new Zen 5 architecture, many hoped there would be some info on Ryzen 9000X3D models. That never happened, but AMD did tell us that it's "working actively on really cool differentiators" to make 3D V-cache "even better."
Obviously i was comparing 8c to 8c you donkIs there even new ones coming out to replace these ?![]()
I just looked and the 7800X3D is listed as 8 coreObviously i was comparing 8c to 8c you donk![]()
No, I was comparing going from a 5800X to the possible 9800X3D, and only then at low resolutions. Prob be a bit near that but not quite imo.So do you think the new 9800X3D is also going be about 50% faster then the 7800X3D
I read somewhere this week that the new boards are coming at the time time as X3D, and read elsewhere that the MSI new boards are released on 30th Sept, ergo X3D 30th Sept f these reports are trueInteresting, I assumed the boards would have launched at the same time as the first round of CPU's.
My wallet will be pleased.
This might not happen anymore in general use like gaming, though. With new series some instructions seem to have gotten big performance jump but games don't use these pretty much at all currently, so the general performance jump between 7k and 9k series will likely be around 10% only, unless they do something really fancy with 3d cache. We are almost at the limits of the silicon as is already, changes from now on will likely be very incremental and small between series.I normally try to upgrade my system when i can get around double the performance
like my last upgrade was from i7-8700k/2080ti to i9-14900k/4090 so i may have to wait a few more years
According to Videocardz (quoting Wccftech - yes, I know!I speculate X3D needs very fast ram for the "sweet spot", which is why they are releasing with the new boards (which go upto 8000mhz) together. Only guessing though
Makes sense, same IO unit as Zen4. Not due to change until Zen6 where they'll be using a new 3nm unit (rumoured ofc).According to Videocardz (quoting Wccftech - yes, I know!), 9000X3D will support overclocking across the board: https://videocardz.com/newz/amd-ryz...ocking-zen5-gets-improved-ddr5-memory-support
On the memory speed front they note:
The same outlet has also shared details regarding Zen5 memory support and overclockability. The new series is said to consume less power and support enhanced overclocking for DDR5 kits. Based on preliminary data collected from qualification samples (which will be identical or better than retail units), the Ryzen 9000 series still targets DDR5-6000 memory as a sweet spot, but the upper limit will be increased to 6400 MT/s while maintaining a 1:1 FCLK (Infinity Fabric) to MCLK (Memory Clock) ratio. Furthermore, they will support up to 8000 MT/s EXPO memory in a 1:2 ratio with 4-DIMM mode.
Yes 30th Sept https://videocardz.com/newz/amd-x870-motherboards-expected-to-launch-in-late-september
9000+ with 2 DIMMs in 1:2?According to Videocardz (quoting Wccftech - yes, I know!), 9000X3D will support overclocking across the board: https://videocardz.com/newz/amd-ryz...ocking-zen5-gets-improved-ddr5-memory-support
