- 6 Aug 2004
- Norwich
Was that the stock sd card? Surprised it lasted as long as it did!Just tried to fire up my RG35XXH, aaaand the SD card is dead. Probably used it 4-5 times....
Code:[ 1145.394548] sd 10:0:0:1: [sdb] Test Unit Ready failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK [ 1145.395210] sd 10:0:0:1: [sdb] Test Unit Ready failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK [ 1145.395299] sd 10:0:0:1: [sdb] tag#0 access beyond end of device [ 1145.395302] I/O error, dev sdb, sector 75840 op 0x0:(READ) flags 0x80700 phys_seg 256 prio class 0 [ 1145.395347] sd 10:0:0:1: [sdb] tag#0 access beyond end of device [ 1145.395349] I/O error, dev sdb, sector 75584 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 [ 1145.395355] FAT-fs (sdb1): FAT read failed (blocknr 1856) [ 1145.405955] sd 10:0:0:1: [sdb] tag#0 access beyond end of device [ 1145.405959] I/O error, dev sdb, sector 96542720 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0 [ 1145.405964] Buffer I/O error on dev sdb2, logical block 0, lost sync page write
Going to use this as an opportunity to try out some additional firmwares. Any recommendations? By all accounts Stock + mod seems to be flavour of the month?
Also does anyone know if the stock ROM contains everything from factory?
I have muOS on my 35xxH - and really like it.
