Anyone got a Honor Magic V3 here yet?
If so any initial thoughts? Very tempted to pull the trigger on one!
I have the V2 the hardware is very good, the V3 looks like an upgrade in many areas, the Magic OS has not been without issue, particularly if you are and ex Samsung Fold user, the OS just has a lack of Polish that has almost sent me back to Samsung, One UI is so much better particularly in Dex mode where more apps work, even the supplied browser doesn't work in Magic Desktop and the keyboard doesn't function right in that mode, its infuriating, I've had to download alternate apps to get a good desktop experience, the only reason I still have the V2 is because the hardware is so much better (from a physical perspective) but should Samsung match the hardware size and weight, the Honor is getting dropped so fast if Magic OS doesn't improve, other annoyances are the constant power intensive app warnings you can't disable and better multi window support on the inner screen with Samsung.
Other things that make the Honor feel like something from the 90s, it doesn't transition nicely across my wifi APs, often hanging onto the weakest signal, I got in touch with support, the response, wifi is hard
Samsung and Apple work fine in my house, also the Honor share stuff causes BT car kit issues, so if you experience a BT kit connecting/disconnecting rapidly then disable that and you should find it is fine. If there weren't these problems with the Honor I'd have bought the V3 straight off as I miss things like wireless charging, gaming is nice on the thin and light Honors inner screen it is great nice to hold unlike my old chunky monkey the fold 4.
Honor also need to sort out the camera software. hardware is probably good again, just the software not quite there, whilst it might be improved on the V3 I doubt it based on comms with support.
All told though despite its glitches I am happy enough to hold on to it in the hope things improve but only because no one has something better IMO, though not tried pixel 9 pro fold yet but online reviews suggest Google can't match Samsung for software either.
