- 24 Sep 2015
Yep, though that stopped with when I moved to the UXG Max and for reasons of lazyness and the fact that Sonos and Sky are friends these days I haven't bothered to fix it.By the way, are you still able to use the Sky Go app for watching recordings from the Q box(es) with your setup (different VLAN etc)?
When I was using the USG I had to configured to act as an IGMP proxy. The UXG Max can also, but it's more designed for getting IPTV working LAN side than inter-VLAN IGMP so the configuration options aren't there. The USG was configured with a config.gateway.json file on the Controller but the UXG doesn't read that so the config that was previously working doesn't apply.
