Looks like a big update for Protect:
UniFi Protect Application 4.1.31
Improvements
- Added Alarm Manager, a powerful upgrade to our notification functionality allowing granular control via rules that include triggers, actions, and custom notifications.
- Existing email / push notification settings will be migrated to Alarm Manager during the upgrade. Please review the migrated Alarms and report any behavior that is inconsistent with your prior settings.
- Added the ability to Archive Footage to CIFS/SMB Servers (NAS).
- Added the Shortcuts feature to the dashboard pane when a single camera is expanded.
- Added the ability to unlock Access doors using the Shortcuts feature.
- Added the AI detection confidence level display to the Detection Highlight and Detections pane.
- Added an option to customize the chime ringtone. This requires firmware version 1.7.10 or newer.
- Added an option for UP-Sense to lock the connection to a specific AP.
- Added the ability to reorder the default dashboard grid using drag and drop.
- Improved browsing-specific detections by splitting up into individual events.
- Improved button placement in the video player.
- Updated the side panel for UP-Sense.
- Reordered the left navigation panel.
Bugfixes
- Fixed an issue where the microphone sensitivity settings would unexpectedly re-appear after restarting a camera with a disabled mic.
- Fixed an issue where a cloud archive account could not be removed.
- Fixed an issue that resulted in incorrect storage capacity calculations.
- Fixed an issue with email/push notifications and system logs for archiving events.
- Fixed an issue where in rare cases Protect restarted in Limited Mode while recovering thumbnails during startup.
- Fixed an issue with Patrol Mode usability.
- Fixed an issue where the group side panel would reappear after resetting the search criteria.
- Fixed an issue with cropped video feeds on ultra-wide displays.
Known issues
- Some actions in Alarm manager has limitations:
- Play Sound works for chimes only
- Turn on light works with Floodlight only (spotlight support coming in the next version)
- Unlock Door/Gate is not showing Access door locks (will be fixed in the next version)
Thanks bud
