- 30 Dec 2013
- Liverpool
I’ve gone from Nvidia to AMD 6950xt used DDU and was pretty much golden no issues.
I know it’s all subjective but for me I don’t think RT is the reason you go Nvidia, their feature set (DLSS, Reflex, RTX HDR) is all significantly ahead of AMD’s comparative options.I can honestly say ive never enabled RT on my 3070ti so ill not miss it.
If a 4080 super is within £100 of a 7900xtx, I’d personally opt for that but I haven’t checked street pricing in a long time.
The feature set on nvidia is just too good. Dlss, vr support, day 1 drivers, dldsr, better hdr support, and that’s before the RT benefits.
Me to not bothered about RT eitherI don’t care in the slightest about RT, so I’m happy. Far better bang for your buck than Nvidia. My 7900XTX has been fantastic. That said, now, depending on price I’d consider the super if I was buying, despite the stupid name.
This is not really good for the consumer AMD giving up on high end cards.....but what do they determine is high end cards like the 7900xt or 7900xtx or are the gonna finish on the tier below.Went from my 1080 to a 7900xtx. Built an AMD system with a 7800x3d so thought I would try there best card which was a sapphire nitro 7900xtx and it's been perfectly fine.
Now the news has come out they won't be making high end cards anymore, on my next upgrade I might have to go back Nvidia.
I suspect this is one gen only, maybe whilst they sort their MCM properly. Should be middle tier next gen 7800XT replacement.This is not really good for the consumer AMD giving up on high end cards.....but what do they determine is high end cards like the 7900xt or 7900xtx or are the gonna finish on the tier below.
Spot on.I'm sure there are plenty of people who have, there's a lot of guff spoken about AMD drivers but you'll find most people here running them just fine. They'll be along at some point to confirm I'm correct on that.
Remember, the people who pop in the card, load the drivers and have a hassle free experience are not the ones you'll find on Internet forums. The ones who have an issue stand out, because they're in the vast minority and present on forums.
For that to happen people who want a more even playing field in the GPU space would have to put their money where their mouths are. If you(the general you) want a company to succeed you will have to feed it some moneyGoing on what I've read, AMD's sales in the high end i.e 7900Xt/XTX are abysmally tiny compared to their sales in the £500 and below market, It makes sense to make the very best products they can for that market to grow their marketshare while at the same time adding features, Polishing drivers further etc.....
With RDNA5 if hopefully their marketshare goes up then they'll return to the high end which will reap the benefits of their refinement of their architecture, Process and so on.
I hope anyway as I don't want a market dominated by Nvidia, That's how we get to mid range cards costing close to £1000.
Hope your right, as I think my 7900xtx is brilliant and I usually skip a generation or two.AMD aren't giving up on high end cards, they are just concentrating on low to mid range for a gen or two presumably to try and gain some marketshare back.
GTX 970I have been on Nvidia since well basically since they come out, but noticing the 7900xt and 7900xtx getting great reviews.
So fancy a change as either of them cards are great by looking at the reviews so was wondering if anyone has made the change
and if so was it worth it or did you change back thanks.
