if Arrow Lake was supposed to be the final CPU what would have that made Meteor Lake ? when this is the kind of performance you getting from Arrow Lake
Confirmed by who? Please don't say MLID
People assume because arrow lake-s has been officially cancelled by Intel in their roadmap, and ultra 300 will be completely new architecture compared to arrow lake
It also seems W11 26100.2152 or newer corrects some of the latency issues.
Most of the latency issues you'll in reviews are horribly loose xmp timings.
Thank you. Still about the same, so i guess it is what it is for now, idk.
used in every CPU review by all reviewers everhorribly loose xmp timings
fact that tuning timings now helps Intel too doesn't mean you dismiss results with "stock" XMP
PS Didn't anandtech test with jedec timings? Definitely did the max officially supported
IMO There should be two sets of results, the first at complete stock with JEDEC base CPU and power limits and then another with unlocked and XMP.surely thats upto Intel to provide guide lines how to setup the cpu for reviewers to follow ? if you get results at stock thats intels fault not reviewers imo
I'm running 26100.2152 and memory latency is still pretty bad on AIDA64.
As I have said before, you are also running below the 6400 base clock which won't help.
I'll test again in a few hours when my RAM arrives from OcUK.
This would be bad, this would be really bad, The 265K here would have to find 49% just to match the 13950HX, a 5800X3D would kick this thing in the face.....
