https://videocardz.com/188838/intel-core-ultra-9-285k-ultra-7-265k-and-ultra-5-245k-review-roundup
so its 6pm UK embargo lifted
17 CET is 16 BSTso its 6pm UK embargo lifted
@Robert896r1 is any of your tuning dependent of silicon quality and the silicon lottery?
I mean the silicon lottery on the Intel side, ignoring any well-binned memory chips. I guess without a wide sample it is a hard question to answer what role, if any, the CPU memory controller etc. play.
Straight xmp timings?
Good on productivity, hit and miss in gaming. Not bad, but they need to try to improve those gaming numbers.![]()
功耗比锐龙7还低!Intel酷睿Ultra 9 285K/5 245K首发评测:游戏性能一言难尽
一、前言:Intel首款采用Chiplets设计的桌面处理器或许是i9-14900KS为代表的酷睿第14代处理器的设计失误,让Intel的攻城狮至今心有余悸,代号为Arrow Lake的新一代桌面处理器酷睿Ultra 200Sm.mydrivers.com
First review where I’d trust the numbers.
TRUSTMEBRO!!!!!!!!!!!Confirmed by who? Please don't say MLID
Time for him to start deleting videosThis guy is a perfect tool.
Just waiting on a cpu or gpu to launch with early access prices.Jeez.....even reviews are getting tight these days.
whats the FPS per watt? what even is that chart telling me in chineseSince some of you are obsessed with gaming power draw
This **** is really annoying, makes reading CPU reviews almost pointless because put together with all the power limits / VRM throttling and what not, the numbers are so unreliable that you might as well just throw a dart at a dartboard and hope the CPU you picked is fastest in 2 months time after Windows build 219582150 and BIOS update 50095.If best performance requires the latest Windows build and turning off VBS, then reviews will be all over the place IMO.
Is that build, 2153, on general release or something a reviewers has to go out of their way to find?
Windows build, correct Windows settings, most recent BIOS, this ain't be an easy CPU to review.
Do we know what Intel's reviewers guide says?
I'd really really like to see this, it would be hilarious on the forums/reddit!!!Nvidia are just about scummy enough to do it.
Ideally you'd test settings for each game and isolate them (certainly things like SSR are obvious only-GPU_taxing) but... let's be serious, people can't even bother not testing with GPU-limited benchmarks for their CPU tests, or lower the resolution, let alone something more complicated. That's why it will be simpler & more accurate to just push the settings up (ultra/max preset instead of low).That only makes sense if you selectively set things like crowd density to ultra, a lot of visual settings on ultra even at lower resolution will massively shift load to the GPU.
EDIT: Though I agree with the overall point - personally I only bother with the results for the settings I'm going to play at and lower resolution with those settings can give an indication of future GPU performance but ultimately that is why you need tests at more than just one resolution/settings profile.
all the real ballers are waiting for 18a anyway? jus the people with FOMO can't hold out.To be fair Intel's roadmaps seem to confirm LGA1851 is going to be relatively short lived with anything other than maybe a refresh cancelled as things stand. But a lot of stuff is still up in the air really as per what happened with Meteor Lake and still some rumours around "Bartlett" CPUs with possibility they might be coming to both 1700 and 1851 even or not at all :s
Interesting results from the early CN reviews. The efficiency seems good (even if the performance is weak, as expected, in gaming) until you run into a properly multi-threaded title, then you can see it's still far from the truly great (7800X3D); power consumption:
considering it also loses badly in cp2077, power efficiency in games might turn out worse than last genIIRC assuming that is a loop of the CP2077 built in benchmark at 1080p my 14700K averaged about 130 watt. I can't say in that context power consumption really bothers me much as at the wall the difference is generally much less stark than the CPU power draw difference itself.
i told a friend of mine i'd probably buy the cpu to sit on my desk 'until i need it'all the real ballers are waiting for 18a anyway? jus the people with FOMO can't hold out.
Nova Lake seems to be scheduled launch around the same time as GT6 will probably hit PC
just donating to the cause at this point.
so much #winning.
