- 18 May 2010
- London
Oops wrong thread.
Use DLSS and whatever settings best give you at least 60fps. No need to have unlimited fps, cap to whatever is a bit below your GPU's max so it doesn't run at 99% at all times, gpu fans spin quieter, less heat etc etc.How best to run this game?
Do I use native or DLSS? Do I cap to 60fps or unlimited?
What’s your configuration?
In the game you should know what your GPU gets max, cap the fps to below that, so if it maxes out at 90fps with dlss etc all on, then cap it to say 75fps. It will still be smooth and responsive whilst drawing less heat and power and have smoother frametimes.thanks mate.Yes hence saying capIn the game you should know what your GPU gets max, cap the fps to below that, so if it maxes out at 90fps with dlss etc all on, then cap it to say 75fps. It will still be smooth and responsive whilst drawing less heat and power and have smoother frametimes.
This works great, thanks.If you're on Nvidia 30 or 20 series and want frame gen, use Nukem9's Universal DLSSg-FSR3 mod instead. That way you can have DLSS upscaling and FSR3 frame gen at the same time, and it's way way superior:
dlssg-to-fsr3 (Replace Nvidia DLSS Frame Gen with AMD FSR 3 Frame Gen)
Adds AMD FSR 3 Frame Generation to games by replacing Nvidia DLSS Frame Generation (nvngx_dlssg).www.nexusmods.com
God, the graphics and performance in this game really are rubbish…
I hopped over to RE4 and the difference in image quality, effects and performance is night and day.
I suppose this is because Capcom has a much bigger team and budget etc.
Not purchased it yet. Waiting for it to go sub £25 as to many other games to play right now. But I did not get the impression that the graphics were rubbish. Not from mrk at least![]()
I hereby lay down a Pepsi challenge for anyone that doubts RE4 looks better
James looks poo compared to my main man Leon <3
Could it be that's the jacket speaking?![]()
www.oksgear.com
