Yup. Virpils are great. No point going VKB or any other from them!
I hear you but for someone who just wants an occasional dabble, but don't want to go right in at entry level (say TM T1000s) the VKB NXT Evo kit is great value and I understand far above quality wise than some of the other options from Logitech etc.
Their Gunfighter MKIV base and Modern Combat Grip is pretty much same cost as a WARBRD-D+Constellation. Just without that no centre cam unfortunately, good for other Sims though for sure and I'm sure their soft centre space cam is fine, just that I got used to having no bumps etc so I'd probably dislike it. Dunno tbh, been around the houses many times.
Winwing looks great value too, I just didn't like the look of it lol. The sticks anyway, rest looks cool. The guy I got the stick from (right hand) forgot to send the cable, springs, cams, and hand rest lol. Thankfully he has found the spare parts in his attic and has shown me he has contacted virpal directly who will send me out a replacement hand rest. I need it as my hand is just a tad to small to reach everything, and tbh its uncomfortable without it anyway.
The buttons seem a bit louder or clickier than the alpha prime, but I appreciate not touching a freezing cold stick straight away (not that it takes long to warm up)
And the money I saved and part of the reason I went for the non-prime was because the mounting stuff has cost me a lot of money.
