Block n' barbs:
My pump bracket:
DDC 18W and xspc pump top:
XSPC pump top:
DDC Apart:
Scrubbed up bracket and pump top marriage:
Double sided foam tape for mounting the pump, lost my much thicker roll which would have been good for vibration isolation, oh well:
Sealing foam strip on the radiator:
Sealing the case:
Fan, shroud, radiator sandwich:
Fans wired up:
Hello, yes we will be working together pleased to meet you:
Why not hide some tubing in this trench?:
The business end, industrial I think:
Adding stuff:
And then....:
Leak testing, didn't get any
Ok I want to say thanks to MNPCTECH in the US for promptly shipping me some screws for my build as well as a cool bottle opener!
http://www.mnpctech.com/casemodstore.html
So the loop is still running, the pump is a bit louder than I envisaged but he might settle down a bit later.
Really happy with how it is looking so far, now it's time for small refinements and sorting the lighting. Will be covering both the PSU and optical drive in vinyl to stealth them a bit. I will actually be stealthing the optical drive too
Need to cover back panel in vinyl as well as make a side window.
Probably going to order aquaero this week and get it installed to control the fans and pump. The fans make a terrific draft even through the rad, amazing. Seems overkill on 100% and too much of a woosh noise.
Oh and actually getting my PC up and working again
I'm uploading a video of the filling process onto youtube for you all to see, bout 30mins left even on a virgin 50meg line! that's 720 content for you...
