Nottingham mate
Just ordered light tinted and plain (clear) perspex last night
And an aquaero 4.0 display system, 10cm and 30cm UV cathodes and some white braiding.
So hopefully this wknd I will have a window made!
@Gtiracer the tubes are too small to fit on the barbs without softening with boiling water first. Then they serve as their own clamp and will not come off with kilos of force. In fact a scalpel must be used and the tubing section binned.
The bottom tube feeding the pump from the res is sloowly kinking! Going to have to drain the loop which will be good practice anyway and put a slightly longer piece in to see if it helps. I refuse to use anti kink coils they look gash IMO in most cases.
I ill install also a bitspower black nickel temperature probe in the remaining port on the bottom of the res
fed to my aquaero it will tell me the temp of the water, just something I am curious about!
Forgot I will also be illuminating the acrylic on the 470 block. Then I may eventually hook up to my RGB for a very slow 'fade-pulse' effect
ATM I am running just a silver coil with the ultra pure water, I have PHN Nuke but have not added any yet.do I need any drops also? Any compatibility issues anyone know of?
