- 15 Jan 2004
- Hall
Hmmm maybe, how do you know its been reset at the bras?PiKe said:You obviously know the system inside and out and no matter what I say I'lll be wrong.
Tim said:Try it now, you may find you've been upgraded already.
Because the BRAS controls the datarate, and thats based off the sync rate (it works out an average and sets it to the nearest .5mbit).Phnom_Penh said:Hmmm maybe, how do you know its been reset at the bras?
Hmm I think I misunderstood you, I thought you meant a radius cap had been put on your line, but what's happened is that the BRA traning period has been reset (I presume you meant this) and that the line will go back to initial 2mb rate? It could probably take up to the three days for the data rate to go back to near MSR then.PiKe said:Because the BRAS controls the datarate, and thats based off the sync rate (it works out an average and sets it to the nearest .5mbit).
You didn't unplug/turn off your router did you?PiKe said:Well it's 3 days since initial sync at 6mbit, so yes it looks like that.
Nope, and resyncs only happens when the line became unstable.Phnom_Penh said:You didn't unplug/turn off your router did you?
Still not fully sure how MAX differs from standard DSL..Phnom_Penh said:Won't do bub.
The most critical piece of news is that most of the regrades occur over night, and it is best to have your ADSL modem turned off or disconnected from the line at this time if the BT Wholesale systems are to upgrade both the line and throughput speeds to a much faster level in the shortest possible timeframe.
The issue appears to be where a line is connected to a router and so on-line when the regrade actually happens, BT do not recognise the new line sync as being from a Max line (it's too quick). Later re-syncs at the same rate do not prompt BT to take any action either. This means the normal 75 minutes for a new or regraded line does not happen. The line should have the rate correctly set after 3 days. The reason some lines appear to work is that they are either slow to reconnect, not on-line during the regrade, or sync at a different rate later. Ironically this does mean that really good lines that always sync at a full 8128M are unlikely to have the speed change appliued promptly.
You should loose the 2mb cap three days or less after regrading.
Depends on which problem you mean, but when the modem is first turned on it should (afaik) sync at 8mb, but will be limited to 2mb for atleast 75mins, as 2mb is the initial data rate that training starts at.OllyM said:Rubbish, it does work.
I did this and didn't get affected by the 2mbit BRAS profile problem.
Phnom_Penh said:If you mean people are being stuck at 2mb after the 75mins, you just unplug your router for 30mins, and then plug it in again, meaning the training should restart.
I know, I'm not going to even consider it until we find out how the first regraded lines end up after the adaption period.OllyM said:Max generally has been an absolute farce.
How long they been on max?OllyM said:Trust me, there are a fair few AAISP customers who are synced at 8128 or near, and still stuck on 2mbit.
niceOllyM said:I know somebody with two Max lines getting over 100 dropouts a day (no joke). His line is all over the place and the DLM isn't kicking in.
. Tolien mentioned someone who'd been losing sync upto 4 times a min, go BT.Phnom_Penh said:Tolien mentioned someone who'd been losing sync upto 4 times a min, go BT.
OllyM said:I suspect it's the same person, or two people actually![]()
I suppose it is to be expected as the rate adaptive broadband technology is new isn't it
