Pdog said:Just browsing this thread and saw your post. I have DG834G v2. Twice last night my connection dropped. I did however upgrade the firmware and since then I have not had any dropouts, I am unsure if it is related or not. Most of the DSL testers state my line can handle 4Mbps. I did notice after the dropouts that when the router did reconnect it would sync at a lower speed. It started off at 6112 then synced somewhere near the low end of 5000. Is that meant to happen? I was wondering what would happen if I unplugged the router and powered it backup would it sync at a higher speed? I may give it a go tonight.
Luke284 said:i migrated from f2s to evolution on the 12th. i turned the router off on the 11th with the new user/password entered. i then turned it on today (no one was at home to turn it on yesterday) synced at 8128kbps and has stayed like that. however only getting 2mb dl speeds!
its been connected for over 3 hrs with out any problems, apart from the speed. i thought turning the router off while the migration/upgrade went through eliminated this problem!?
do i just have to wait 3 days now then?
ohh well. all that disconecting over night for nothing then!stoofa said:That's about the jist of it - yes.
Tim said:Yep, sync at 8mbps, 235kb/s max download, 50kb/s max upload - Nildram.
Lets see how long the old DG834 can hold an 8mbps connection![]()
Do you think we could put this in big bold writing at the top of the N & IC page? It was posted first 10 days ago!Richeh said:It's a known problem, speed should pick up after 3 days, and should be working properley by the end of 10 days. Nothing to do with your ISP it's BT.
If after the 10 days you are still getting 2MB throughput then phone your ISP.
csmager said:Do you think we could put this in big bold writing at the top of the N & IC page?
**Update**partycan said:Don't know if it's been mentioned but looks like eclipse have got a regrade option now. Though tried the regrade link after logging in, but got an internal error bah!
Anyone else managed to get it too work?
partycan said:Cheers, finally went through at about half 6 and they completed it just after 10, I shoud be regraded sometime before 24th fingers crossed!
