lay-z-boy said:
LOL. whats with the bridge haha.
lay-z-boy said:
PinkFloyd said:Its mentioned if you read the thread the pics are from.
But he doesn't say why....
Does he know something we don't......
Where did you get the top 120mm blow hole done.... great picsDreamcaster said:heres mine, done couple of things to it - added 120mm top blow hole and modded the front hdd cage to take a 120x38mm fan.
3 120x38mm panaflo fans all together.
Neon said:its stupid :|
Re-submit Post, found if pics are over 640x480 they delete post & pics, has happened to meandywhir said:removed the link(dam fascists lol)
any idea on my posts guys ??
FAQ said:You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you. The forum Dons/Admins reserve the right to judge individual signatures, particularly those deemed to contain material of an adult or offensive nature. If the Dons/Admins think the signature is unsuitable for a family orientated forum, then it will be removed. If the user then replaces it without making changes, they will be suspended.
Its not the picture size its because he posted a link to a competitor.BFG_9000 said:Re-submit Post, found if pics are over 640x480 they delete post & pics, has happened to me![]()
