Man of Honour
DP or HDMI, both the same going to the GPU.
Yes and yes.So to use HDR we have to enable it every time we want to game and then disable it when we are back in windows?
Also are people auto hiding the windows taskbar with these monitors?
No you probably won't, go with a nice slick 1440p oled imo. 4K can sometimes be a bitch to run!I just worry I’ll not see that kind of FPS at 4k.
True, but he may have an old card or even worse.....an AMD one!!! *shudder*DLSS Performance. Job done![]()
I have a 4080 and went from 3440x1440 and playing games maxed at 120-170fps to 4k and getting 40% fps less on average. Not worth it especially when you are used to playing at 120fps and higher, unless you plan to upgrade to 5080/5090 when they come out. I liked playing at higher fps so much that have just ordered 360Hz 27 inch oled. 120fps is my playable minimum right now.Is the drop in FPS worth it going from 1440p to 4k?
I’m seriously thinking of upgrading my AW3418DW and am torn between the 27 inch and the 32 inch.
Having recently experienced 1440p at 165hz it felt so smooth, I just worry I’ll not see that kind of FPS at 4k.
Oi don’t insult me like that. I have a 4080 Super, so it should be more than capable of 4k.True, but he may have an old card or even worse.....an AMD one!!! *shudder*![]()
exactly my experience!You see I was quite content with 120hz until I experienced 165hz and the difference is quite big!
Thanks for the feedback.
I’ve now reviewed or at least used at least a dozen QD-OLED and WOLED models combined, and they’ve all suffered from a degree of VRR flickering which has the potential to bother some people. And none have been as ‘offensive’ in that respect as your average VA LCD in this domain, at least for normal ‘in-game’ fluctuations that might occur. If there is such a thing as a normal in-game fluctuation (of course there isn’t – it very much depends on the game and your system). My overriding general feeling is that, for whatever reason, I tend to find WOLED flickering more noticeable when gaming on my system. The best performer in this respect was actually the first model I tested and one I owned for a few years – the Dell Alienware AW3423DW. This one benefited from a G-SYNC module, which performs some degree of compensation for the gamma fluctuations occurring in a VRR environment. This reduces but does not eliminate VRR flickering.
