- 14 Apr 2014
- Hampshire
are they keeping the software on these current with the 2023/lastest tiled android auto updates ?
at £300+ pounds - the MOST interface still leaves the bottleneck of sending audio through the android phones audio mixer, before it get transmitter wirelessly
versus a dac/amp (eg. recently discussed match up 7 bmw system discussed in what I did to my car)
with which you can send perfect bitstream from your phone, or ....... just put the media on a usb thumb drive directly into HU
[ the mr12volt web site is confusing/wrong
MOST Bus BMW CIC CarPlay & AA Interface
Brand: Mr12VoltModel: P2000 LIGHT - CICMOL The brand new Mr12Volt P2000 LIGHT series Are now with built-in BT / WIFI antenna and all connectors are relocated on the same side. The best CarPlay / Android Auto interface product is now even more installation friendly! Mr12volt P2000 LIGHT-CICMOL...www.mr12volt.comAdditional Technical Data:Operating Temperature: -20 - +80 degree centigradeDAC resolution: 18Bitwhy is a dac needed if the system has digital audio/MOST throughput
I couldn’t tell you if the software will remain up to date, but they have done a good job of keeping them up to date so far.
I believe the DAC is if you’re using it for analogue output instead
