That explains why all the thumbnails I've seen of the M5 reviews on YT are shots of the rear of the carit has this grille.... Where did things go so wrong at M division
Guess I'm in the minority of liking that, the front corner reminds me a bit of Kryten though....dont know why, just all the angles.It looks a bit like a new 530e I had while my car was having some warranty work done, it was an M Sport Pro (so has the black grille with the lights around the edge, which I don't dislike).
This one was adorned with about £10k of stick on M performance carbon fibre bits, and expensive wheels.
Despite the challenging looks at some angles, it rides very nicely and is more hushed than my current G30 LCI and the interior is quite good. However, the entire car is less tactile, you are never going to convince me that pressing a touchscreen is better for adjusting the climate control... They've also removed the adaptive cruise settings from the steering wheel, so now you have to go into options on the touchscreen to adjust the distance, which makes no sense.
It all feels more modern, but it also feels a bit naff in places. The specs are a bit of a mess too, you can't have full electric memory seats at all without spending £5k on the Comfort Plus pack, which is just crazy.
I certainly wouldn't fancy spending £65k~ for a decent spec 520i... I'd consider one in future though.
Lol I cleared the fault but comes straight back. No chance of getting away with that!clear the fault, p/x the car pronto
That depends. I could easily cover 10k miles peak commuting in 2 months.Irrespective of COVID, 2 months is nothing.
OK but it is mileage or age based so that's a different problem altogether.That depends. I could easily cover 10k miles peak commuting in 2 months.
Fair point, but this car with the late service had covered nowhere near that amount:That depends. I could easily cover 10k miles peak commuting in 2 months.
It's showing as mileage based from the pictures I took:OK but it is mileage or age based so that's a different problem altogether.
Absolutely ridiculous how they are wrapping this options up like this. I understand it’s something to do with legislation or certification, but it’s not reasonable to have to pay 5k to get electric memory seats on a car that’s already so expensive and apparently premium.
Sun Protection Glass isn't included in any of the packs, so you have to individually spec it (£470) - which means loads of cars will have it missing...
Finally, some good news.
