BMW and M Power Owners
I would not be fitting a Ghost to a brand new car. It ties directly into the electrical system, way too risky.
If you are in an area with a high theft risk, I would maybe reconsider... or just make sure your insurance is good.
It isn't even a deterrent - best to do what we used to do in the old Clifford days and just stick the "GHOST" sticker in the window :cry:
Wheel lock is the only "foolproof" device that also deters IMHO.
How isn't it a deterrent?
Car doesn't work without the code haha.
I've already smashed the window at this point haven't I? Also doesn't stop the car being towed? Not sure, just seems an expensive way to solve a problem a "Ghost" sticker may solve. In fact I think I am going to buy a Ghost sticker :D
£590! are they selling you a barrel of it?!
Well exactly my reason for the question. Doesn't seem reasonable at all so would like to tell them to forget it and I'll take it to an Indy. But need to know if £590 is even normal as I've never had coolant changed before.
It stops the normal theft attempts.
Dead.
Why are you having the coolant changed?
Actually had a high pressure fuel pump go bad so that's being changed, but then they noticed the non-BMW coolant. They recommend replacing the current pink coolant and was told £590. I don't mind changing it out for BMW branded but not for £590.
I'd suggest the actual cost of the fluid would be around £70 at retail prices (I think it's 7.5 litres), and it should be very little labour (in theory it's just undo a bottom hose and let the fluid drain, then reconnect and refill, and bleed by opening a bleed screw).
For perspective my local Mini Specialist charges £85 for a coolant change (although it's only ~5.2 litres on an R56 mini)
Actually had a high pressure fuel pump go bad so that's being changed, but then they noticed the non-BMW coolant. I asked how much it would be to replace the current pink coolant and was told £590. I don't mind changing it out for BMW branded but not for £590.
How do you know it isn't original coolant?
The current BMW Coolant (G48?) is blue, however there are reports all over the internet of different colours being used from the factory.
If different colours have been used from factory then that is a good question. In the wording of the report they simply say it's got the wrong one because it's pink.
HT-12 (Pink or Green) is newer than G48 (Blue)
It will depend on year as to what should have been used in an F30
(From 01/01/2019 it should be HT-12, before that should be G48)
Source of images above, and some good info here:
Do have to get bleeding right and let it warm up and re-check a couple of times , so some responsibility.
.... had an expensive lesson where inadequate bleeding may have contributed to head-gasket, after I changed radiator.
The on-board storage for music on my F06 is around 20GB. Has anyone ever replaced the HDD with something bigger? e.g. an SSD. This would leave the two USB slots available for other duties.
have you had erratic behavior from a 128/256 big flash drive not being read.
